Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Washer door stuck with some kind of piece blocking
  • 15,935 Answers
It appears your door lock has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
2004 envoy back door won't closew just bounces back help !
Hey Susan,
Sounds like the latch/lock mechanism in the door is stuck in the "locked" can look at the door lock, if the latch piece is in the way of the vehicle latch piece, you can move it out of the way with your hand/fingers. There should be nothing blocking the door latch mechanism..I hope this is clear enough...
Sep 10, 2017 | Cars & Trucks
Washer won't start....just beeps 3 times
Yes, door strike and if it is stuck inside the door latch that will have to be replaced also, unless you can pull it out. Part# 8182634
Apr 20, 2014 | Kenmore Elite 45986 Front Load Washer
Ge gbvh6260fww washer
if it is off near the door then you can put it back on but do not forget to put the clamp back on or it will come of again
Aug 18, 2013 | Washing Machines
1995 Voyager Front passenger door latch stuck - door won't close
insert blade of screwdriver behind cam like piece pull up on handle and push up on cam like piece this should reset the latch
Dec 10, 2012 | 1995 Plymouth Voyager
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
My whirlpool duet washer will not move forward with the cycle and will not allow me to open door. I have tried the pause/cancel button and depressing the end of cycle button on front. nothing so far,...
Assuming that you mean the washer stops at the spin cycle and door remains locked, then thats normal safety precaution when tub has water in it. If the drain pump is bad or restricted this could be a reason for this happening. You can get the door opened by taking off the bottom front portion of the washer also known as a kickplate. Once this is done with the machine unplugged you can reach up on the right side an there usually is a plastic tab that you pull that will release the door catch. While your down there you can check the drain pump, located in the front center of the machine. On most of the front load the pumps have a center piece facing forwad that you can twist to the left to unscrew and remove any debris that could be blocking water flow. If this is the case you still may need to replace the drain pump depending on how long somethings been in the pump. Hope this helps.
Jun 01, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin out on a maytag neptune model number MLE2000AYW have already changed motor and motor control board
Your problem is on Machine control board(located on dryer,top right front)if you can check look for R43(any color change)or R11 if your door luck light is not on.Check with Maytag for this problem,thay have recall on machine control board.
Jan 22, 2010 | Maytag Washing Machines
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
22 people viewed this question
Sal De
 Brian Main
Brian Main
