Question about Kitchen and Much More Dishwashers
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
My Whirlpool Dishwasher ADP 4601 has a constant flashing light and does not appear to be heating up, i have cleaned out all the filters and checked the waste, can anyone help me please ?
  • 31 Answers
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Posted on Dec 13, 2014
  • 69 Answers
SOURCE: dishwasher adp 4601 when switched on the pump
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Posted on Aug 09, 2009
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
SOURCE: My Whirlpool ADP 5550 dishwasher has a red light
Managed to track down a copy of the manual from the Whirlpool website. The red light is an electronic indicator to show that there is no rinse aid.
Posted on Jul 22, 2009
  • 1121 Answers
SOURCE: my adp 4601 dishwasher light on the start button
there a sensor error, motor error, or board defective, send to repair.
Posted on Jan 14, 2010
heatman101
  • 43501 Answers
SOURCE: My dishwasher Whirlpool ADP 533-1, no heating the
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 07, 2010
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
My dishwasher Whirlpool ADP 533-1, no heating the water. The temperature sensor NTC is OK. The relay in the electonic card is OK, but their coil no receive 12 VOLTs DC. I want de manuals of ADP 533-1
heatman101
Sep 05, 2010 | Whirlpool 18 in. ADP530 Free-standing...
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
Aug 09, 2009 | Whirlpool Dishwashers
Whirlpool adp 44045 dishwasher not drainign and geen light constantly flashing - how do i drain system
First pull off hose on your garbage disposal and look for a clog.If no disposal then un do the drain hose under sink and look there.
Jun 03, 2008 | Whirlpool Washing Machines
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Dishwashers Logo
954 people viewed this question
Top Kitchen and Much More Dishwashers Experts
Are you a Kitchen and Much More Dishwasher Expert? Answer questions, earn points and help others
