Question about Technics Audio Players & Recorders
No cable for technics
No cable to take the power from the stero power amplifier to the stero control amplifier
model number su-c800um2e
possible other helpful numbers se-a900sm2
se-a800sm2
would be willin to buy the cable.
I had the same problem with my sua900s pre-amp.
If it's the same cable, you need a (I think 6 pin) mini din cable, male to male. It's sometimes called a PS2 cable (nothing to do with Play Station!). It's the same cable that runs from your mouse into your pc and is readily available for about £5 from online computer retailers. Check the number of pins first though!!
Posted on Feb 18, 2009
Got the same problem..
Got the amplifier secondhand whitout any cabels...
So thanks for the adwice.. I'll try right away...
Posted on Jul 24, 2010
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
The imput selector on my technics su-c800um2 stereo controller behaves erratically
This is due to a possible fault in the digital logic switcher which is at the input selection and could be a failure of the logic gate or a fault in the subprocessor IC.
You can remove and clean the amplifer if there is noticable dirt , also check for DRY SOLDER or faulty connector or joints if a TAP bring this fault up.
Jul 02, 2012 | Technics Audio Players & Recorders
I need an Operator Manual for a Technics Amplifier SU-600
HI,
I have the User manual of Technics SU-600 in pdf format. If you can sent your email address the i will sent you the manual.Its not possible to sent the manual through this site as it is a pdf file.
OK
Oct 26, 2011 | Technics SUV500 2-Channel Amplifier
What is technics amplifier su z2 ic number
HI,
The out put ic number of Technics SU Z2 is SVITK2038. If you can sent your email address the i will sent the schematic diagram
OK
Oct 10, 2011 | Technics SUV500 2-Channel Amplifier
How do i connect a subwoofer to my stero technics su-800mk2 amplifier
You would connect any non-specific subwoofer according to its needs:
passive = to an amplifier channel;
active (self-powered) = per its manual and the capabilities of the source.
Given the lack of a specific subwoofer facility on the SU-800, you need a sub that can be driven by full-range speaker level output. Its manual would describe the procedure. Keeping in mind that most active subs are pretty much the same speaker-level-connection-wise (if they allow it), you could find just about any manual and wit would get you running.
http://archiwumallegro.pl/technics_sua800_mk2_wysoki_model_krakow-998303435.html
Jul 06, 2011 | Audio Players & Recorders
Need the part number for D407, D408, Technics SU-8088 amplifier
The remainder of the topic statement has gotten truncated. Can you please update this with the model number. I have access to the service manuals dor Technics units and can get you the part numbers. I just need to know the model number. Thanks, Dan
Jun 11, 2009 | Technics Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
350 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
