Question about Toshiba Satellite P100 Notebook
Shuts down with no reason
My laptop shuts down while I'm working on it (skype, genera browse) and often will not reboot, only after several attempts.
please advise.
  • 4 more comments
  • Niri Bensadon Feb 09, 2009
    thanks guys, but the laptop is on a flat desk and the fan works big time.
    anything else?
  • cjbar Mar 24, 2009
    i have the same problem and have blown out fan and heat sync w/o taking completely apart. The machine runs fine in safe mode. I have restored with Toshiba Recovery Disk, but it still shuts down and reboots in normal mode while either working or surfing with IE7.
  • Anonymous Apr 08, 2009
    I have the same problem of overheating, and I want to reach the cpu/heatsink/fan for a cleaning.
    Are the any instructions available for reaching these ?
    thanks
  • argirisb Apr 08, 2009
    Are there any instructions available for reaching these ?
    thanks
  • davesehome May 11, 2009
    It is ironic that this seems to be a chronic problem for P100. This has been an issue for my machine for several months. Once it cools it works okay. Although I havent yet taken it apart I would like an update on others that have taken the machine apart, cleaned cleaned out the fan, cleaned the heatsink and it corrected the problem. I only use my system on a table and expect it is clean inside.
    DJ
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Sounds like it is getting overheated. Do you hear your fan? Also, it must lie on a flat, firm surface like a table for the vents under the computer to work.
  • 741 Answers
While I am researching further would you mind voting on my initials solution by filling out the three blocks as you did TampaNative. Would really appreciate it. I will get back with you soon on other alternatives.
Posted on Feb 09, 2009
    President:
  • 778 Answers
When a processor overheats the system will shut down to avoid physical damage to the processor. An indicator is that you'll have to push the power button twice to get the PC to start again.
Do as Rtrahan suggests.
  • Frank  Fernandez
    Frank Fernandez Feb 09, 2009
    The symptoms you describe suggest overheating processor regardless of the cause. It could be a heat sync clogged with dust or heat sync paste/tape broken down from age and so on.
    I know of no other condition that would cause a hard shut down as you describe. You can try letting the laptop sit unplugged over night and time the run time until it shuts down and time the run time shortly after a shut down and I'll bet that it runs longer when it's cold than it does when it's warm, suggesting processor over heat again.
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
My laptop shuts down randomly
Tell them to give you a NEW computer. You got a lemon. They WILL give you a new one if you've had this much trouble with it. I'm serious, they do it all the time on lemons. Be assertive! They will cave.
Jun 29, 2012 | Dell Computers & Internet
Samsung laptop purple light
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 18, 2012 | Samsung R540 Laptop
While browsing net r watching movies my lap(acer extensa 4630)shut down itself
The processor has to perform large amount of work while surfing , especially while usingvideos and animationMultiple windows/tabsnumber of browserwhich in turn produces lot of heat . The heat produced is managed by the interneal heat sink and inbuilt cooling fans.But this cooling process may get affected by the blockage in air vents due to dust.So to safeguard the laptop form overheat, it automatically shuts down.
One simple try :Go to the Adobe flash properties and disable Hardware acceleration for online content. That ought to stop the system from rebooting or crashing.
Else...Its better to call a technician when it shuts down often.....
Apr 10, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Skype
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Jan 21, 2009 | HP Compaq Presario V2000 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Mio digiwalker c220
hold the red button down for 15 seconds until it shuts down. then repeat to reboot. Reboot may require several attempts.
Aug 20, 2008 | Gomadic (RTC122921) Power Adapter, Power...
SKYPE CONNECTION TO VTECH 7100 PHONE
go to www.vtechcanada.com click on cordless phones then click customer support and click on software down load and look for "For Windows Vista operating system:
USB7100 Setup version 2.35 – For use with Skype." save it and after that reboot your cpu and open your skype , log in and then open vtech cordless phone suit and check if all of the options there has a green check mark .. ok :-) and it will work and make sure you are using the 3.0 or 3.8 for your skype because 4.0 would not work. you can down load it in google skype version 3.8 or 3.0 ..
Aug 08, 2008 | Vtech USB7100 IP Wireless Phone
I have to shut down twice
I will first assume this is a Windows-based PC. Does it even attempt to shut down? Do any programs close? Go to the task manager (Ctrl + Alt + Del) and look and click on the processes tab. While the Processes tab is showing, try to shut down following your normal procedure. If the number of processes running (bottom left corner of Task Manger) starts to decrement (at least one fewer) then the shutdown procedure is just getting hung while attempting to close a program. Do this first and let us know.
Jan 13, 2008 | Dell Inspiron 6400 Notebook
Open Questions:
Toshiba Satellite P100 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
