Question about DISH Network IR Remote Control
Remote Control #1 will no longer control TV
Some friends were in my home while I left for a two day vacation. When I came back the remote would not work. It would turn on the TV, but would not change channels or go to the guide. The TV button remained lit, even when I would hit the SAT button. If I tried to adjust the volume, it would get louder and louder and I would have to control it with the TV remote. I replaced the batteries with fresh ones, but it didn't work. I have shut the receiver off for 10 seconds, then tried again. The second TV that is running off this receiver is working fine with the #2 remote. What can I do to fix it?
Thanks,
Rob Balch
    Sergeant:
  • 326 Answers
Inside the remote there is a circuit if that circuit turns faulty some functions work properly and some does not work.you can get the remote control opened with proper screw driver and thin knife like material.and clean the internal circuit and check out.otherwise it needs to be replaced.
Posted on Feb 08, 2009
  • 19,396 Answers
Remove batteries from remote and put in fresh batteries, this will reset the remote.
  • Ginko
    Ginko Feb 08, 2009
    Sorry I see that you replaced the batteries already, if you still have the same problem then remote is faulty.
    Remotes are not serviceable, you can try taking it apart and see if you see any lose contact or broke solder joint, or blown component, otherwise they are not worth fixing, get replacement, or call factory to see if they can offer cover on this fault.
    You should find factory support phone number on the remote instructions.
  • Ginko
    Ginko Feb 08, 2009
    Check the following website to find replacements:
    Dish Network Replacement remotes Silver, Universal
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
I purchased (from a friend who relocated) a Phillips/Magnavox model #9P5511C102 TV with a Magnavox remote control.. I used it for a while and then got Direct TV. Now, I cannot remember my tv code. After...
It sounds like you need a replacement remote. :-)
Unfortunately, from what I've found researching this for you, you can no longer buy the original remote. However, there is a substitute available that should be able to perform most if not all of the functions of the original.
The substitute remote is available for $35 from:
http://www.remotes.com/store/philips/9p5511c102.html
There is a picture of the suggested substitute on the sales site so you can see if it might be what you need. The site says it offers a 1 year money back guarantee, so if it isn't right you can always send it back.
Mar 18, 2011 | Philips Magnavox Learning Universal Remote
My remote for the samsung htc550 home theater system does not switch back to the set top after I have switched it to my tv. I no longer have a working remote for it and do not know how to switch it back....
Press the BD Receiver / TV button twice in quick succession. The light should now be orange which indicates it will operate the Home Cinema system....Pressing it twice again in quick succession will turn the light green indicating it will operate the TV.....Unfortunately the useless operator manual with the system does not tell you this....
Apr 29, 2010 | Samsung TV Remote Control
I have a sony bravia davhdx274 but i no longer
Yes, but you will have very limited control for internal adjustments.
You can purchase a new remote from www.remotes.com
or 1-(800)REMOTES and they will ship it to you within 5 days.
Good Luck !
Feb 09, 2010 | Sony BRAVIA DAVHDX275 Theater System
Cannot turn on TV when using the remote control. Is there a code sheet for the Philips Universal remote control?
The problem has been solved. It's my friend's remote that I asked about. The maintenance department replaced it with another one.
We are nursing home residents.
Thank you for your attention..
Jan 21, 2010 | Philips Universal PH301S Remote Control
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
Volume control
Try this:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks what device are you using to control volume, please choose the TV.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Jan 09, 2009 | Logitech Harmony 550 Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
DISH Network IR Remote Control Logo
244 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
