Question about Samsung LNR269D 26 in. LCD Television
The HDMI connector broke loose from its mounting inside the tv.
The rear HDMI connector broke loose from its mounting on the circuit board inside the tv. Can the HDMI connector be re-attached to the circuit board or should the entire board be replaced?
  • 6,784 Answers
Hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
Posted on Feb 08, 2009
LED TV has sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 20, 2016 | Televison & Video
Model d52w20. The F connector on the rear panel is broken. How can I replace it?
The F connector probably is soldered to a circuit board inside your TV. You would have to disassemble the TV to get access to the board to unsolder the broken connector, remove it, and solder the replacement connector on the board.
Mar 30, 2016 | RCA Televison & Video
Seeking Parts Advice for Broken Samsung TV
I would also just buy a new board .BUT keep the old board for parts! This way if anything goes out you can compare components on the board etc and figure out what's wrong and also use the parts for repairs when you need them. Some of those boards HDMI ports have the tiniest solder joints and you can easily bridge them make the board useless anyway. These things are way more fragile than the old CRT tv's. Just be a little more careful next time.
Dec 30, 2012 | Televison & Video
My 52" Toshiba DLP just dropped an HDMI connection... There are two connectors on the back, both have worked fine until just now when one disappeared from the inputs menu on the screen.
I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
Hope these info will help you.
Jun 04, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
I need to connect a DB15 plug to a HDMI plug. do
ok, I found out what I really needed was a HD15 connector, which is not as hard to find as a BD15 connector,,
I still need to find out what type of plug the HDreciever will have, either a HDMI or RGB. I guess I have to trust that my TV has a circuit board that will translate the infor after getting the correct cords...
Wish me luck....
any other help or suggestions would still be nice....
Nov 04, 2009 | Philips 60PP9352 60" Rear Projection...
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Mar 30, 2009 | Tomtom One XL GPS Receiver
It is possible for the HDMI connector to be re-soldered back on. However as the pin connections are small & delicate it is possible that some of the pads on the board may have been damaged, if this is the case then a new board would be required.
Feb 08, 2009 | Philips 52 In. LCD HDTV
"No Connection"... My first attempt with HDMI SUUUUCKS- HELP
The connector board inside the tv is the one has circuit traces already broken. there is nothing outside the tv can be done. The HDMI conector is high end technology solder. finally the solution is to replace the conector board inside the tv.
Jan 02, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Samsung LNR269D 26 in. LCD Television Logo
502 people viewed this question
Jerry Greenberg
Jerry Greenberg
