Question about Philco (R) 841.205 CD Shelf System
Philco 841.205 Power Transformer
I need to know the output voltage or the power transformer. My transformer was fried by a power surge and is not identified with output voltage. It's only markings are BS-48-0004 & E67585 which I can not find any info on.
Larry Ber
  • Anonymous Mar 31, 2014
    Would like to buy a BS-48-0004 E67585 transformer for Philco record player
Hi:
...I have a brand new one exactly the same (Philco) that I will sell you for ten bucks.... but I don't know where you are?
Please e-mail me at: brodi@telus.net
Posted on Mar 24, 2009
Tv dead during lightning
Could be minor or maybe done for but here goes. Some flat panel TVs have the main power cord with one of those small transformers built into the plug end that converts 120volt ac to DC power. Output voltage should be listed on the transformer tag. You need to find someone with a voltage tester and see if the TV plug end is showing DC voltage. If not the complete power cord needs replaced. If that checks out-- the next thing is to remove the complete TV back cover and look for fuses right near the power plugs into the TV. The fuses should blow out first from a lighting surge. The problem is how much of a surge you got. It may have damaged the power supply board in the TV which may need replaced. Hope this helps
Jul 12, 2015 | Televison & Video
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
Jan 15, 2013 | Logitech Speakers. S-120
Resetting a tripped kitchler low voltage transformer
Model number is not known.
I did not know that Kitchler transformers have a circuit breaker.
Usually they have an override switch.
Did you set the timer to override, what does your product manual say?
Is the transformer humming? Kitchler transformer are supposedly non-audible, but there should be some indicating sound. The humming sound indicates the transformer is working.
Does the unit have photoeye? Cover photoeye with black tape.
Test outlet with circuit analyzer.
Check outlet voltage: if you have 120Volt then output is 10% or 12Volts. If you have reduced voltage, then output is still 10% but might be lower than needed to operate bulbs.
Plug timer into different outlet.
Test output terminals with low voltage tester.
Did you have power outage or nearby lightning strike? Transformers are not protected from surge.
Suggest you contact kitchler.
Kitchler.com website is useless
888-412-4877
7711 E Pleasant Valley Rd
PO Box 318010
Cleveland, OH 44131
Kitchler products are probably warranted through the seller.
Kitchler product manuals are almost non-existent.
Scan your product operating manual and parts list into .pdf format and post on web for others to access.
Aug 09, 2012 | Hardware & Accessories
Rudd furnace>>>> power surge.
Some circuit boards have a built in transformer and others have the transformer that sits right beside the board depending on the age of the furnace. First, look for a small 3 or 5 amp fuse on the circuit board. Check it, and if its good, and you have a small ohm/volt meter. Check your transformer. You can either ohm it out or just check for voltage. You have a "high" voltage side and a "low voltage" side of the transformer. The "high" voltage side will go to the power (120 volt) that comes into the furnace. This would probably be the side that would burn out during an elec. storm. To ohm the transformer: (This will be your best way to check)
1) shut off power to the furnace
2) pull the two wires loose that go to the "high voltage side"
3) put the leads from your ohm meter to each wire that goes to the transformer, and you should get some kind of reading. If not the "high voltage" side of the transformer is burnt out
You can follow those three steps to the "low voltage side as well, just remember where you take any wires off.
Be sure you have the power turned OFF. Good luck, hope this helps you.
Apr 18, 2011 | Heating & Cooling
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
I have a HT-3000 Casio keyboard. I can't get any power when I turn it on. The power indicator light does not come on. Is this keyboard worth fixing? or can it be repaired at a reasonable cost.I am not...
Of course, don't try higher voltage. Something wrong with your transformer, it should be 9V as an output. Parts of component inside transformer have broken, such as resistors, capacitors or even IC. I'm affraid it cause your kboard power circuits have broken also.
Oct 14, 2009 | Computers & Internet
NEW 600W L.V.TRANSFORMER DOES NOT PRODUCE ENOUGH POWER
This is more than likely what has happened . I am going to guess that your original low voltage trasformer was a 120 volt .6KW. Or 600watt transformer that has one lead from it to the lights . The newer less expensive transformer is also 600 watts , but the new one may have 2 sets of wire terminals on the back( 4 screws ). If this is the case , you have a transformer that is 600 watts output but it has 2 seperate 300 watt outputs that won't run 600 watts from 1 set of output screws . You will have to seperate the lighting load and may have to run an additional low voltage wire to half of your lights . In other words . Put 300 watts of light on 1 set of 12volt output screws and 300 watts on the other se of output screws .that will solve your issue . Good luck and enjoy your lights again . John
Nov 03, 2008 | Garden
MS9700 secondary voltage
This product is designed to operate on normal 120V 60Hz AC only.
Nov 18, 2005 | Emerson MS9700 CD Shelf System
Philco (R) 841.205 CD Shelf System Logo
608 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
