Question about Phoenix Digital PD-394 Car Amp
Amp on "protect" mode
On the RCA input end of my PHOENIX DIGITAL PD-394 (PD394)
4-Channel 1000W AMPLIFIER w/ Fan Cooling System there is a small light which says (green) power and (red) protect. Well right now the light is red and i am not sure what this means or what i need to do to fix it or reset it.
  • 323 Answers
Hi, what you need to do is unplug all the connections to the amp. The amp goes into protection when the circuitry over heats.\
First decrease all your gains to minimal volume.
Connect your 12+V, remote, and ground.
See if the protection light comes on then.
Next plug in your RCA cables.
Check protection light.
Then plug in your subwoofer cables.
See if you are still in protect mode.
Hopefully everything works alright again.
Just slowly increase the gain to see what the cut-off is. Make sure you aren't dropping the ohmage too low on the amplifier. Check manual for correct wiring and such.
Posted on Feb 09, 2009
  • Dalynn Turner Feb 09, 2009
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
Blows fuses (the ones on the amp) when ever power is connected to the amplifier. What could be causing this?
It sounds like possably a screw was ran through the power supply wire to the amplifier. Because what your discribing is a short to ground. If you removed any panels or molding to run the power wires double check to see if a screw was ran through. If so repair the wire with electrical tape or heat shrink tubing.
Dec 22, 2010 | Phoenix Digital PD-394 Car Amp
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    I realy need help, pleas!!!
    Your problem may be in your input rca connections not getting proper contact or in the wrong way , if the input is not rca lead and is hi end input,as in wireing off the back of your head unit to the amp it may be a short in the wireing, you will need to check all your wiring if so, also make sure all your earth leads are clean and are big enough to take the amp size.
    May 27, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
    Red light is on when i connect input cable earthquake 1000w amp
    Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
    Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
    Sony amp model 1652z
    1000W max power
    <b>
    165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
    200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
    400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
    </b>
    OTL (Output Transformerless) circuit
    Pulse power supply
    Line & High Level Inputs
    .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
    80 Hz, -18dB/octave Low Pass Filter Switch
    Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Crown amp xs900 will not reset
    naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
    Features
    • 2-ohm dual (per channel) : 1200W
    • 4-ohm dual (per channel) : 900W
    • 8-ohm dual (per channel) : 600W
    • 4-ohm Bridge : 2500W
    • 8-ohm Bridge 2100W
    • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
    • Housed in a rugged, all-steel 2U chassis
    • Microprocessor-controlled protection system.
    • Flow-through ventilation from front to back.
    • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
    • EIA Standard 19-inch rack mount width
    • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
    Inputs
    • XLR-¼" combo connectors: One per channel
    • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
    • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
    Output
    • Balanced XLR connectors (2-channel models only)
    • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
    • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
    • 4-Pole Speakon output connector (2-channel models only)
    • Accepts a 4-pole Speakon connector.
    Dec 31, 2008 | Crown XS900 2-Channel Amplifier
    Thumping speakers - no power light is on - wired correctly
    the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
    Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
    Phoenix Digital PD-394 Car Amp Logo
    1,007 people viewed this question
    Top Phoenix Digital Car Audio & Video Experts
    xxxxxx xxx
    Are you a Phoenix Digital Car Audio and Video Expert? Answer questions, earn points and help others
