Question about Karcher 2500 PSI Pressure Washer
HOW TO FIT A DUMP VALVE
CAN ANYONE PLEASE TELL ME HOW TO FIT A DUMP VALVE ON TO A, V REG VAUXHALL ASTRA 1700 TURVO DIESEL
How to get detergent to feed into Greenworks 1700 psi washer
The only way that it will feed detergent is by using the correct nozzle for the detergent. It's a lower pressure tip which allows the valve for the detergent to open. It's the black tip. It's either that or if it's an older one, there is a twisting wand that controls the pressure and spray pattern, which has to be twisted to the widest pattern with lowest pressure
Nov 10, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Tip
WARNING: Do not allow PW to run "dry"
It is recommended that once pressure washer is in operation and water flow thru wand is there ,that you do not allow off period between burst of no more that 2 minutes or you highly risk damage to your pump,not engine, due to overheating. See if Dump valve is adjustable,cheaper models not adjustable. This valve senses pressure/heat build up in pump when trigger is released, and is a secondery backup to release such heat/pressure to avoid pump failure. If you have repeatly left trigger off for more than 2 minutes in for prolonged periods of time,this is not good.
Thanks and Please Rate a Fix Ya
John jj505
on Apr 15, 2009 | Honda 8 HP Engine
What is spill valve in karcher 502
Another name for bypass or unloader valve. This is a safety device for your pump head for when the pressure gets too great or water temp too hot they are pre set to dump water and prevent damage to the internal valves and seals hope this helps!
Brad
Jul 05, 2014 | Karcher 2500 PSI Pressure Washer
Install high pressure hose. Cannot get shaft of hose fitting to go deep enough into fitting so retaining clip will engage
There are several different configurations for these fittings. If you bought a generic replacement hose, it may have a different fitting than what is on the machine. May have to replace the fitting on the machine, or buy a hose specific to your pressure washer.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Craftsman 1700 leak
craftsman 1700 pressure washer 1700 elect. with steam
it sucks down the soap down when I wash my golf cart. I do it fast any way slowing it diwn
Jan 28, 2013 | Craftsman 1700 PSI, 1.3 GPM Electric...
My diesel burner on my pressure washer smokes real bad. Could I have a leak, if so where would that leak be? It is a alkota
HI, here is a few pointers that may help you ,
  1. if the smoke is white , that usually indicates water in the diesel, empty fuel tank and replace/clean the fuel filter
  2. if the smoke is black that indicates excess diesel or unburnt fuel , normal fuel pump pressure is around 8 to 9 bar (you will need a gauge to check this ), another cause is often failure of the fuel nozzle to correctly atomise the fuel (remove nozzle and clean (a small sintered fuel filter inside this )
  3. the burner electrodes should have a blue angry looking spark across them ,when checked (BE VERY CAREFULL WHILST DOING THIS as in effect you have a flame thrower ), usual gapping distances are around 6 mm
  4. the electrodes should be sharp pointed and not rounded or pitted
  5. a final cause is commonly a leaking fuel solenoid which can cause fuel to drip into the burner/heating coil assembly ( replace the solenoid
as you can see this can often be a complex and dirty job to repair and it might be better to contact a local service agent in your area .
Hope this helps
Jan 28, 2010 | Briggs & Stratton Pressure Washer...
Losing pressure somewhere
Hi, I work in the italian factory of Karcher. In my opinion the problem is caused by the breaking of the collector. This is a black component of plastic where is inserted the detergent suction valve and the safety valve. To replace this component you have to go in a repair center Karcher.
Nov 24, 2008 | Karcher 1750 psi Electric Pressure Washer
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
346 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Phil Rivera
Are you a Karcher Garden Expert? Answer questions, earn points and help others
