Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
Remove schlage deadbolt
Double-cylinder deadbolt. builder grade schlage. No screws on outside or inside. only access is from panel around bolt that faces door jamb. How do I get this thing out to replace?
  • 1 more comment
  • aaronhowse Feb 08, 2009
    faceplate on outside and inside just spin. spinning counter-clockwise. no spots in the brass at all. leveraged small screwdriver under edge of it but no luck. really just bending door. completely sealed. I have no idea of model of this thing but I read somewhere some models have allen bolts only accessible from behind deadbolt plate. I don't see that either.
  • Anonymous Mar 31, 2009
    outside cyl failed. I can easily re-key this, but - how do you disassemble the da-- thing to be able to fix.????? I tried the twist, even used a pipe wrench, no go unless destroy it. Then drilled out to a larger size the two small holes on the inside part. Can see the screws but no way to get at them. In my tool bin I have a dissasembled B362, it has no holes at all - and the beveled covers are stamped and pressed into the bases where the screw go. Go to Schlage site and all you can get is info on the single cylinder model. I do maint. on a old building that has many of these things and I hate to destroy them to rekey, new sets cost big bucks and it is not needed. JUST TELL ME HOW TO DISSASEMBLE THE DA-- THINGS. John in FL
  • cap3d May 11, 2010
    Same problem. Can't believe there is no info at Schlage. No solutions in over a year???????????
  • 3 Answers
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Posted on May 07, 2010
    Problem Solver:
  • 4 Answers
There should be a small spot in the brass usualy on the bottom to pry the faceplate off. or the face plate may twist off try both under there you will find the skrews
Posted on Feb 08, 2009
  • rgw4 Jan 18, 2011
    Just as soon as I read this I went... oh yeah... this has to be it. I went right out to my lock and used a screwdriver to pry the inside plate off. Gee, and under that were two screws to remove the lock.
    Sad part is that I installed this lock some 20 years ago - you would think that I would remember this!
  • bob_holland
    bob_holland Sep 22, 2012
    pried my faceplate off and nothing was there but a hard piece of steel. Any ideas how to remove this thing
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
How to remove plugs from schlage deadbolt?
Thank you for your inquiry. These are small plastic plugs on your double cylinder deadbolt. These are just held in through friction. Just take a small screwdriver and pop them out. Factorylocks.com can help you with your Schlage hardware needs.
Mar 29, 2013 | Schlage BE365-PLY BE365PLY626 Satin...
Double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Oct 22, 2012 | Schlage Deadbolt. Double Cylinder Deadbolt...
I have a Schlage that was in when I bought the house. It is a double key deadbolt lock. Recently my key just started spinning around on the inside lock. The outside one still is functioning. I took a...
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jul 26, 2011 | Schlage Locks & Locksmithing
I have a schlage deadbolt, keyed on both inside & outside but neither have any screws to remove. How do I remove the deadbolt?
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Sep 24, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Schlage deadbolt installed about a month ago. The key will not turn the lock from inside but will from outside. Any suggestions?
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Sep 24, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have a Schlage double cylinder deadbolt on security door. If I try to lock/unlock from the inside, it works fine. From the outside, the key turns and turns but the bolt doesn't move. I am trying to...
there are 2 buttons on 1 on either side of inside key slot.. those must be removed... more than likely you will destroy them when removing..under you will find square drive screws or phillips..https://www.schlage.com/en/home/products/B62FFF.html
Oct 15, 2017 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How do I unmount a schlage keyed deadbolt? There do not appear to be mounting screws on either side of the deadbolt housing.
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Sep 27, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
9,953 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Jim Thurston
Mike
Tom Weglarz
Tom Weglarz
Level 1 Expert
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
