Question about RCA RT2300 System
Need Service guide or schematic of system
Took out the fuses without making sure I noted where each one went back. Need to know which fuse goes where.
  • stacky55 Feb 10, 2009
    Thanks to John for this answer. Jadre had already discovered the printed values of the fuses on the circuit boards. He had a little problem until he realized that the board was used for three models and they used different fuses in different places. He figured out which line went to each model. His problem is that he can't resist TV's, stereos, any electronics deserted on the curb and he has a pretty good record of bringing them back to life. This time he had pulled fuses from several things and several places in some of them and didn't mark which fuse came from where. Next question -- where do you find SB fuses? He can find most of the right sizes at Radio Shack but they are often FA instead of SB.
  • stacky55 Feb 11, 2009
    Thanks for the suggestion, although I could not find the fuses I wanted.
  • 336 Answers
I do not have a manual, but check on the board and inside chassis for a sticker that should tell you the fuse value and location. 99% of the time it's in there. The fuse itself will also be marked with its value
Posted on Feb 09, 2009
My 2002 suzuki gsxr 750 F key will not turn in the ignition, I don't know what the problem can be. However I checked the fuse box and there is a fuse missing wonder if that's the problem?
Repair Manuals
Repair manuals (also known as Service Manuals or Workshop
Manuals) contain the information you need to perform routine
maintenance and repairs. These manuals generally include
periodic maintenance charts, step by step repair instructions,
troubleshooting information and overhaul procedures. Wiring
diagrams are usually included. If you need to overhaul an engine
for example, a repair manual will guide you through the process.
Repair manuals are used by the service departments of your local
dealership.
Owners Manuals
Owners manuals (also known as Operator Manuals) include the
information you need to understand how to safely operate the
related piece of equipment. These manuals also include very
basic information on maintenance but do not include detailed
overhaul procedures like a service manual. Owners manuals are
usually included by the dealership when you purchase a new
vehicle.
Parts Manuals
Parts manuals include detailed schematics of every major system
that makes up your vehicle. The drawings include individual parts
as well as parts groupings. Every parts schematic has a
corresponding page that lists the part number, quantity and
description of the part. These manuals are helpful for
understanding how an assembly goes together and for ordering
parts.
Repair Manuals Online
Aug 20, 2015 | Suzuki Motorcycles
Speedometer stopped working pulled all fuses mileage lights back on gas guage now worksspeedometer spun all the way aroundchecked fusest didnt spin back aroundstuck under the little plastic nub by 0
Google year & make of car for fuse panel fuse diagram. Do the fuse trick you did. If you notice any corrosion or caked gunk on fuse legs...replace fuse....If problem persists it's probably the VSS Vehicle Speed Sensor which gives the vehicle speed to the speedometer.
Mar 29, 2015 | 2002 Dodge Neon
How do i take apart the Kenmore 19606 to fix the fuse?
The first time is a little difficult; but it get's easier every time. I found after mine blew its first fuse, it blew more and more often; then almost any time it got jammed; while sewing real heavy material; and when I tried to sew real fast. So might as well buy several fuses when you go to buy one. I had a hard time finding a fuse locally, until I just happened to call Radio Shack and they had them. There are usually 2 fuses, so check to see which one is blown and take it with you. Make sure you buy fuse that does not blow as easily -- think they called it a slow blowing fuse. Radio Shack helped me to buy the right one. I purchased a higher rating the last time and it seemed to do better -- but I could not find where this was recommended and I am no expert on fuses, so let Radio Shack advise you. Just do not buy a lower rated fuse.
Make sure you note where each screw goes back at, I didn't and had some screws left over the first time I finished. Take masking tape and write on it where the screw goes, then use that piece of tape to stick the screw to a piece of paper or aluminum foil. Trust me, it will help. Now how to to do this:
I didn't remove the top cover, I just loosened the screws enough to get the side panel off. I don't recommend taking the top off all the way, because my dimmer knob came lose when I took it all the way off. If you want to take the top off you can by removing the 2 large screws, plus the small one under the handle.
Remove the small screw on the bottom that screws into the right side. Remove the right cover, where the power plug is.
Lay the machine on its back and remove the screws on the bottom. Make sure when you take these screws out you do not move the embroidery arm; or you will have to adjust the feed dogs before it fits back together.
CAREFULLY move the bottom cover out of the way.
Inside the body of the machine you will see a black box held in place by three screws. Remove the screws and, as you slowly pull the box out. One of the wires on mine was not removable. One wire was real short and it was tricky to make sure I had it plugged back in when I put it back together. MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
On the other side of the box, remove the two screws that hold the cover on.Inside, remove the two screws that hold the board. Be careful not to touch anything on the board
Looking into the machine from the right side (where the plug is) you will see two fuses. One will be blown. I used some real long needle nose pliers to take them out. Use the tweezers to replace with the new fuse and reassemble. Make sure it touches the metal on both sides or it will not work.
When refitting the base unit, make sure the feed dogs are in the right position -- this is what I was referring to when I said embroidery arm.
I didn't replace all my screws in the bottom until I made sure it worked. If it doesn't check the short wire where you took the box out; and check to make sure the fuses are in the slot correctly (these are some errors I made the first time.)
**ALSO DO NOT OVER TIGHTEN YOUR SCREWS. I did and mine got stripped out.
The local sewing shop wanted $120 to replace the fuse; which is about all you can get for the sewing machine if you try to sell it. I am a retired single 62 year old lady so if I can figure it out so can you. It took me almost an hour the first time, but now I can do it in 15 minutes. I still have my machine, but purchased a newer model and only use this one for straight easy sewing.
Good luck and let me know if you need any more help.
May 31, 2014 | Kenmore 19233 Computerized Sewing Machine
I need to know how many fuses
One suggestion: Repost your query, being sure to include the make and model of the receiver. Without that information there's not a lot of help anyone can give you.
Mar 26, 2012 | Audio Players & Recorders
My 87 honda cbr 600 isnt getting power. i went over a bump and later on my bike just died no neutral light only headlight. took off the fairing to notice a wire from fuse box is disconnected and i dont...
I had a 1988 hurricane, I feel your pain. It could be an ignition wire, your best bet would be to order a clymens or haynes shop manual for that year it should have the full electrical schematics. On another note search out Honda motorcycle forums in google there are many forums with riders than can help far better than I can..sorry
Feb 03, 2018 | 1987 Honda CBR 600 F Hurricane
Need a diagram of the schematic fuse box for 1979 chevy elcamino
Are wanting a "schematic" (wiring diagram) ? or a diagram of the fuse box? (Your question is a little confusing) If you are wanting a diagram of the fuse box, all I can say is "good luck". Those were not even available back in 1979...you'll really have trouble finding one 32 years later! The fuse box should be marked which fuse is which anyway...that's the way they did it back then.
On the other hand, if you are looking for a wiring diagram, you can possibly find one if you contact the sales department at AllData.com Their DIY information available online only goes back to 1982. Howerver, they also have "vintage model support" for professional AllData subscribers. I have gotten wiring diagrams from them in the past dating all the way back to the 1960's. You might check with them to see if there is a way they can get you the information you need without having to sign up with a professional contract.
Please post a comment to let me know how this goes so I know how to advise future requests like yours. (I see similar requests on this site regularly.)
Jun 04, 2011 | Chevrolet El Camino Cars & Trucks
Bad storm, lightening strike outside then TV went off and will not come back on.
I would start with your power supply. If you took a surge it is possible that you only blew a fuse. If it is a blown fuse, make sure you only use the same type fuse.
Apr 12, 2011 | Westinghouse SK-32H240S Television
Hi! My Acer al1751 lcd monitor has following problem: In startup power comes on, display flashes twice, then goes off. On windows desktop picture is visible about 1-2 seconds, then monitor goes to stand-by...
It odes the same when attached to another PC/ We just want to make usre it is not PC problem.
I would suspect the caps first.
Please download the service manuals so you will know how to take it apart.
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=al1751&kategoria=monitor&kat2=schematics
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Acer AL1751B (Silver, Black) (Black,...
Monitor flashed a few times and the display went dead. No display.
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1916W&kategoria=monitor&kat2=schematics
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Sep 30, 2010 | Acer AL1916W 19" LCD Monitor
2002 Durango: I have a 2002 dodge durango and my brake went to t...
Most of the Gen 1 Durangos had the useless rear wheel ABS. This fuse most likely goes in the the PDC or power Distribution Center under the hood next to your battery.
How is the pedal now? Your 02 has rear drum brakes which sometimes need to be adjusted to keep a firm pedal.
May 17, 2010 | 2002 Dodge Durango
RCA RT2300 System Logo
97 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
