FixYa.com
Tags:
Panasonic Lumix DMC-FX8 Digital Camera
How to unprotect the memory card (by 11 users)
posted by ngas on Aug 01, 2007
I cannot put the memory card into unprotected mode again.
How can I put it back, because I cannot take shots or even edit some settings if the card is protected. Please answer.
Comment by ngas, posted on Aug 06, 2007
JACKBOY>
thanks.. I tried it but my computer's not compatible with PDF formatted files. can you just give me the steps on how to unprotect my card please.
Comment by ngas, posted on Aug 08, 2007
Thank you I almost have the solution. One more question, where can I find the write-protect switch?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
10 Other Users Have The Same Problem
Comment by Guest, posted on Jul 11, 2008
Hi whenever i turn on my camera it sais protected card and i cant do anything on how do i fix it
Comment by Guest, posted on Jun 21, 2008
i try to take pictures or upload pictures and it says that my card is protected and i can't fix it then .
Comment by Guest, posted on Jun 10, 2008
i just fixed mine. it took forever to fidure out. on the sd card there is a little peice that moves up and down so that it locks it so you can not delete files. all you need to do to unprotect it is slide that little plastic peice to the other side.
Comment by brandi babie, posted on May 14, 2008
i cant take a picture or delete any of my pictures, because it says "Memory Card is Write Protected" how do i unprotect it so i can take pictures again?
Comment by Tinak781, posted on May 02, 2008
i put my memory card into the computer to take the pics off, when i put it back in my camera it says protected card and i cant use my camera.
Best Solution
posted on Aug 01, 2007
FixYa! (100)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3561 votes
Check the manual - there is a comprehensive manual in PDF format of the CD
Comment by jackboy, posted on Aug 06, 2007
I cannot because I am unfamiliar with your camera and card.
I can suggest two more things.
1. look up[Google?] the type of card you have and try to see if you can glean any information from there - some cards have a tiny switch, other rely on a camera switch.
Does your camera have a switch with a 'Key sybol on it?
What sort of computer do you have that does not 'know' Adobe document reader?
It is universal I believe.
and is free to download.
Finally go the the customer support at Panasonic - where you may be able to download some FAQ's to search or a Q&A box.
Comment by jackboy, posted on Aug 08, 2007
the switch is self evident on either he card or the camera in they have such a thing.
As staed spme cards do have them other do not
the same with the camera there is a switch with a 'Key' symbol if hr has one.
If you cannot see such a thing then your model does not have it.
If you stll cannot locate a source for your problems try the customer support at Panasonic
Rating Locked! (?) ngas has rated this solution as FixYa!
Solution #2
posted on Apr 19, 2008
FixYa! (100)
karynna
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
i need help too
Comment by karynna, posted on Apr 19, 2008
i fix it thank u my memory card has a switch
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jun 20, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
if the switch still doesnt work try using a different computer i tries to do it on windows vista and it didnt work but then i used it on my xp computer it was working so yeah~~
Can you Help with these Digital Cameras problems?
my problem
My camera was working fine,... Answer This...
near-black screen on my...
Good afternoon, I have a... Answer This...
My Lumix DMC-FX8 shows
My Lumix DMC-FX8 shows me the... Answer This...
Panasonic Lumix DMC-FX9
My Panasonic Lumix DMC-FX8... Answer This...
Won't remain off
When I turn the camera off,... Answer This...
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 28, 2008
I put my card in my printer to download some pictures and it moved the switch on the card, I put the switch back but every time I put the card in the camera it pushes the switch back. what can I do?
thank i fixed mine.my memory card has switch
thanks
i cant take picture it says my memory card is protected
how do i fix this? i need my camera to take picture
Comment by Kari02, posted on Feb 01, 2008
I have the exact same problem! I pulled all of the pictures off my memory card and put them onto my computer. When I put the memory card back into my camera it said "memory card is protected" and I can't take any pictures! How do I solve this?
Comment by 123018137, posted on Dec 26, 2007
my camera is locked too and they are all our family photo's on there i do not have a manual and i have tried panasonic's FAQ but there is no solution on there.
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
