Question about Sony GDM-400PS 19" CRT Monitor
Screen image on GPS 400 PS jiggles
After multiple years of perfect use, the screen image on my monitor jerks left and right or with a slight clockwise-counterclockwise rotation - or both.
What's the problem? Is it hardware or software? Is it some glitch in the Mac OS X 4.11 which will force me to reinstall it (hopefully not)? Is there driver or other software for the monitor that will fix it?
  • pabbott Feb 08, 2009
    How do I get an updated driver for this Sony monitor?
    Problem Solver:
  • 23 Answers
Make sure that the driver is updated. Then if it is, contact apple.
Posted on Feb 08, 2009
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My 2 year old Syncmaster 740N often has multiple faint images behind text in any program and multiple faint desktop icons making it look "smeared"; some days worse than others; resolution is correct at...
Well in monitor you can do one thing - disconnect the monitor cable*(VGA Cable) from the tower and chk still if u have the same faint screen that means monitor gone bad if not than uninstall the Grapics Driver and shut down computer... if u have internet than restart and go to device manager ( Run - devmgmt.msc) under display adapter right click on grapics name and update driver.
Oct 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
AOC 26" LCD 619Fh Problem
Go to "Picture Boost" option in the "OSD window". Then turn on the "Bright Frame" option and after that make the "Frame Size" to 100. That's it now you can get a perfect sharp image...it worked for me.
Mar 07, 2009 | AOC LM729 17" LCD Monitor
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Blurry screen, takes ok pictures
Well you may be right or yet another dud screen Canon support will advise - but as it has been repaired previously- it may be time to replace it
Apr 22, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Image center drifts, bad keystone, jiggles
Hello, the repair seems possibble to me. One of common reasons for the above mentioned error can be bad soldering (contact). Ask a pro to do the job for you. If you need more info please advice. Arpi
Mar 22, 2007 | Sony CPD 400PS (White) 19 in.CRT...
Sony GDM-400PS 19" CRT Monitor Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
