Question about Frigidaire Affinity ATF7000E Front Load Washer
Error code ddo will not start wash I have the exact same problem!! I bumped the underneath of the detergent door and the front part came off and was lying on the ground with a magnet. Now it won't start, it says "ddo". BUT I went to get my friend's detergent drawer and put it in my washer and still got the same message.
    Sergeant:
  • 326 Answers
Frigidaire washer
has “ddo” error code. its a problem of dispenser magnet.
for more details click the link
ddo is Dispenser Drawer Open
Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing
Dispenser magnet.
http://applianceguru.com/forum2/18591.html
click the link
Posted on Feb 08, 2009
    President:
  • 2,110 Answers
The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap,
  • Sibananda Jena
    Sibananda Jena Feb 08, 2009
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
We are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 27, 2009 | Kenmore 43142 Front Load Washer
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
This indicates a problem with the door interlock switch and until resolved the machine will not start.
Sep 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
Our washer has an error code of DDO.
ok if it is the rigt thing for that code there will be a switch on the door have a pen or some thing you can use to trip the switch to thinking the door is closed. and unplug the unit and replug it in.. todays age every thing has to rebooted
Dec 16, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidare front load washer error code
Could be "detergent drawer open". Try opening and closing the door shut. There is a magnet there which shows that the door is closed or open. Use front loading washing powders preferably.
Nov 29, 2007 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
155 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
