Question about Jandy Lite2 LG400 Ceramic Compact Heater
When igniting, the Jandy 2 lite has tremdous flameout from unit.
When the Jandy 2 lite pool heater is not used for an extended period of time, I have a tremendous flameout from the unit. The unit is not used for a 2 or 3 month period(winter months). I turn it on after this period of time and the unit ignites like it should. However, there is a flameout and it is actually very scary. Today, it knocked the front cover off where actually observed the flameout(blue flame). Please tell me what the issue may be.
  • 10,865 Answers
I suspect that dust or debris of some type accumulates inside of the heater during months of nonuse. Store the unit in a box or a plastic bag and see if this solves the problem. good luck with it.
Posted on Feb 08, 2009
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 heater gives FL4 display
F is an igniter failure. Try the following. A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. C. Replace igniter.
Jul 10, 2009 | Jandy Laars Lite2 - 125,000 BTU Propane...
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Jun 17, 2009 | Jandy Lite2 175,000 Btu Propane Gas...
Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Feb 15, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite2 LG400 Ceramic Compact Heater Logo
247 people viewed this question
Top Jandy Heating & Cooling Experts
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Paul Carew
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
