Question about LG 42LC2D 42 in. LCD HDTV
The picture is "frozen" on the screen
No matter what channel we are watching, it shows the same picture
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Have you checked on the remote controll , theres a button that freezes frame..Press them all one by one till it clears? usually turning off and on resets this/
Posted on Feb 08, 2009
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
The audio works and the channel changer works but the screen is frozen with one image
HI Newton
All the data goes through a Mainboard to be processed before it is projected on the screen.
This would either be the DMD Chip that has gone faulty or the Mainboard.
Both are reasonably expensive to replace , so repairing would a better option.
Have you tried resetting the TV.
Apr 17, 2008 | Televison & Video
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Picture problem
If all your wanted is to widen the picture then just push aspect or format on your remote control and put it on either 16:9 or full. But if your referring to HD then an HD picture fills the screen by itself no matter what setting you have the tv set to. If the screen isnt full then the program your watching isnt broadcasting in HD at that time. A common misconception is that because its an HD tv or an HD channel that it always should show in HD. This isnt true. It goes by the broadcast
Apr 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Aug 28, 2009 | Toshiba Televison & Video
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Scattered picture bars on screen
if the bars are not there when watching a dvd or vcr then i would point to a grounding problem with your cable antenna/.
Jan 11, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
LG 42LC2D 42 in. LCD HDTV Logo
189 people viewed this question
Computer Repairing
Computer Repairing
