Question about HP Compaq nc6000 Notebook
Hp Compaq nc6000 Bluetooth and Wireless BIOS Problems
I just formatted my Hp compaq nc6000 and I found out that the Bluetooth and the Wireless button refused to work, all from BIOS, but I don't know how it got disabled from the BIOS settings, Someone should please help me on this because I really need the Bluetooth and the Wireless functions of the Laptop. Awaiting your responses, advices and solutions. Thanks in advance
  • 1 more comment
  • Femi Williams
    Femi Williams Feb 09, 2009
    Well, thanks for trying, I see this problem as more of BIOS
  • aminu daura Feb 25, 2009
    my HPnc6000 Blue tooth is not working
  • Femi Williams
    Femi Williams Mar 05, 2009
    I couldn't understand the language. May be someone can help me to translate it.
    Problem Solver:
  • 11 Answers
For Wireless and Bluetooth to work the necessary drivers will have to be loaded in. There are at least 3 different wireless cards, but if you formatted the hard disc there will be no way to go on line to get drivers. I suggest you get all the drivers you need from the HP web site using another PC with internet access and put them on a CD to load onto the NC6000. You will probably need most of the following SP files: 25081, 25800, 25985, 26997, 27957, 28427, 29294, 29528, 29697, 30157, 30308, 30332, 31463, 32579, 32586, 32883, 33632, 42209, 48447 also dotnetfx.exe from MS
Posted on Aug 27, 2012
Ho avuto lo stesso problema col mio portatile acer ho risolto aggiornando il bios
Posted on Mar 03, 2009
  • 153 Answers
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
I cannot find my bluetooth driver after formating the set up for hp nc6ooo
http://www.driversforfree.com/omn_ofm_omd_dd/hp/compaq-notebook/nc6000/hp-bluetooth-driver/search.aspx
Here is the site to download it again.
Jun 24, 2011 | HP Computers & Internet
My wireless button on my Compaq nc6000 does not work. Is there any other way to turn on my wireless?
right click on my computer and go to manage
than go to device manager.
Under network adapters, you can see the wireless driver.
Right click on it and hit enable if it is not already.
May 22, 2011 | HP Compaq nc6000 Notebook
I have hp nc6000 note book but i dont know how to use it's bluetooth network pane adapter or wifi.
watch here :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
and at Driver - Network section you found driver and utility
after install you have control on wireless and bluetooth
regards,  alex yo2ldk
Nov 12, 2009 | HP Compaq nc6000 Notebook
Just bought this laptop - cannot get the Wireless
If wireless card is listed in device manager under network adapters-that means you dont have to install it. If you running on vista, go to control panel and find ssomething like wireless contol manager or wireless assistant and see if its not disabled there. may also be disabled in bios settings. on windows xp-check if windows has possibility to manage wireless networks or its blocked by third party software. for example i use bt voyager wireless card and its managed by bt software. built in cards are likely managed by windows. type services.msc in run box and see if wireless zero configuration service is enabled.
Oct 21, 2009 | HP Compaq nc6000 Notebook
Compaq nc6000 laptop wireless connection
Wireless connection? If so, make sure the wireless device is enabled on the newer one. If it's a red light, the wireless device may be faulty. If so, just get an external USB wireless device and use that. Check to see that the same lights are on with both PCs.
Mar 04, 2009 | HP Compaq nc6000 Notebook
Cannot reinstall Windows on my Hp Compaq nc6000
I know I just had the same problem today...when getting into the bios...try using a "multi-bay" boot and have the cd booted first then the hd...That's the only way mine worked to "trick" the system to boot from the cd...it took a few times of stalling after that but with frustration and regathering with patience, it finally worked...you might have problems with the devices not being recognized after it does load unless you have an easy driver set to install from cd...otherwise you might have to manually install them to make them operate correctly. *hint: using the device manager to see any '?s' and reinstall drivers helped me*
Feb 05, 2009 | HP Compaq nc6000 Notebook
Help me out pls; my bluetooth and wireless are un funtional
Your laptop has a button which activates and deactivates the wireless network and bluetooth. Your manual should provide you with the detailed information as to where this button is.
Feb 01, 2009 | Computers & Internet
Wireless for Compaq NC6000
where is the on and off button above the keyboard
Jan 25, 2009 | HP Compaq nc6000 Notebook
HP COMPAQ NC6000 notebook HELP ME PLS
restart with os in drive
constantly click F8 options will come up highlight the option to boot from cd or cd/dvd then enter
if that don't help let me know
Jan 07, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
2,960 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
