Question about GE Profile JGS968 Gas Kitchen Range
GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
When gas is turned on oven heating element works but gas won't flow.
power is on but no gas and flames thru burner for broiler or oven. It uses an electrical pilot. This stove/oven is only 3 yrs old. help!
TX!
Al
  • 3 more comments
  • axvieux Feb 10, 2009
    Appreciate your help Sea Breeze...I have already checked the manual...to no avail. Do you think the glow bar or bake valve has gone bad?...need to be .replaced
    Sea Breeze ....Indeed my range is an GE XL44 Model # JGBS23BEA6WH. It uses standard knobs...the only digital item is the clock and timer. When the knob is turned on the Igniter/Glow bar turns on...stays red hot but the gas does not flow. The stove works just fine. It is puzzling...I am not sure where the thermostat is located (possibly behind the oven knob?)....I could locate the Norton ignitor and the valve. I think we are getting somewhere....
    please follow-up. Thank you.
  • axvieux Feb 11, 2009
    Sea Breeze...I will spend the next couple of days, after I come back from work, exploring my range. I appreciate your time. Whether I am successful or not I will let you know. Many Thanks. Al
  • mombo1 Mar 10, 2009
    I have a GE xl44 range. The stove works great, but the oven will not always light. Sometimes I can manually light it, but sometimes it lights by itself. The light glows in the back but the pilot light doesn't light. I had the gas company come out and they said that my gas valve is clogged. What does this mean?
  • axvieux Mar 21, 2009
    I had a similar problem...and I needed to thank Seabreeze for his recommendation. I replace the ignitor ($67) and the gas stove has been back in operation the past three weeks with no problem. I saved myself at least $200 extra for troubleshooting and labor.
    Seabreeze is the best in the business.
    Now I have top deal with another problem with a leaky gas water heater....leaking from the bottom ( 1 gal a day ). That one might be tougher than the GE oven. I welcome any suggestions.
  • GE Master
  • 4,655 Answers
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
  • 1 more comment
  • John Tripp
    John Tripp Feb 10, 2009
    If you did see the igniter lighting in the oven then it leads me to think that if your oven has digital controls and temperature setting that the problem may be in that area. Would you open the door and try to read the complete numbers so I will be looking for the correct parts breakdown. I think you listed GE XL44 gas oven. I need some numbers like this to get on the right print. I will need a number like (JGS968BEK1BB) for example. The gas will not turn on in oven area unless the igniter lights. If the thermostat is broken it will not tell the gas valve to open and allow gas to come into oven area to light. Let again know what you find and I will try to assist you on this. Thanks, Sea Breeze
  • John Tripp
    Check to see if the broil feature works. The electric igniter must stay on in the oven bottom lower or the upper broiler. The igniter is hard to see with the cover on the bottom and top. If the igniter is not lighting in the section that you have the cover off, the gas will not stay on. Igniters are very fragile so use care when removing and installing. Do not turn the gas on high with the covers off or you may have a flash fire. Just long enough to view them working properly. If bake or broil feature does not work, it is possibly the thermostat probe on inside wall of oven, if that is bad it should turn the gas off and not stick with gas setting high or ever on. Another feature that may cause a problem is timed cook being set on some models. The gas valve is located when bottom drawer is removed and you look inside for the valve and a lever that could have been turned off during cleaning that area. The only other cause is the gas valve is boken, or no elecric power to igniter. I hope this helps. Let me know what you find, Thanks Sea Breeze
  • John Tripp
    The answer to where the thermostat is located. The probe is located inside oven and it has a copper tube that go through oven wall and then mounts to back of the temperature or bake/broil knobs. I know this is difficult to solve but following this series of steps will help you resolve the problem. Let me know if this is helping you, I really would like to get this oven working correctly for you. ..Sea Breeze
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi ... my stove does not heat up...I think the ignitor is not lighting up at all.. I tried to run the self cleaning option and stopped the cycle in the middle..it was heating then... now its not heating up at all... could this be the reason why its not working? how can I fix it.....
Posted on Dec 18, 2012
I am going though the same problem and you need to get a clip on amp meter and check that the wire leading to the gas valve from the ignitor is showing 3.2 to 3.6 amps flowing when the bake procedure is running. It is very simple to test, you remove the bottom drawer of the oven and clip the meter around the wire, turn on the oven and watch the meter reading go up. My meter rose to 2.5 amps which is not enough to cause the gas valve to open and let the gas flow.My ignitor does glow very bright and very hot but it is not letting the proper amps flow though the circiut.I hear this is the a common problem and easy to fix by replacing the ignitor. I also hear that there are less expensive options than the ge models available. Going shopping for those now. Good luck.
Posted on Mar 21, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
Dec 05, 2009 | GE Kitchen Ranges
The oven does not heat up on my GE Spectra XL44 but the broiler and stove work fine.
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
Oct 30, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGS968 Gas Kitchen Range Logo
2,727 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
