Question about Whirlpool Dryers
Has power but is not running
We just bought the dryer and it had the initals af it unclogged itself but now my husband tried to turn on the dryer and it has power but the drum or the heat is not coming on any suggestions?
    Problem Solver:
  • 4 Answers
If it is an electric dryer it has a 220 plug. the problem is in your wiring either the "pig tail" or wire that hooks up to the dryer is hooked up backwards. or your plug has power but only to one side of the plug. i know it sounds funny but its true. there are three holes on the outlet. the one closest to the middle is the ground and the other two are hot. if your hubby is a mr fix it he should have a multi meter set it to "ac 250" or "ac 500"and check both sides of the outlet, make sure leads on the meter are plugged into the right holes on the meter, or it could be a painful mistake! if you only have power on one side you found the problem. turn the power to the dryer off. if you dont know which breaker it is try turning the dryer on, then go to the panel and turn off the breakers that say 30 amp off and on until you hear the dryer turn off. then take the cover off of the outlet, you might find a burnt wire ,most likely the red one. if you feel confident enough you might be able to find enough slack in the wall to rewire it. cut off a few inches and rewire it like it was. and presto instant heat in your dryer
Posted on Feb 08, 2009
    Sniper:
  • 79 Answers
Hi , All tumble dryers because of there nature have a very sesative (spelling) thermal cutout on the dryers heater matrix ,When the machine clogges up with dust the temperature increases inside the machine to such a level the thermal fuse blows , On some machines where the dryer elememt is theres a resetable cutout , (push the pin in) but on most once its tripped you have to buy another element assembly , ( there around £40).and while the machine is in bits all the dust has to be cleaned out? If your good with a multimeter you could test the circuit on the heater , youll get no reading if the fuse is busted.
Output drainage error
YOU HAVE TO UNCLOG THE FILTER AND THE WATER PUMP ITSELF. CHECK TO MAKE SURE THE WATER PUMP PROPELLER IS NOT OBSTRUCTED? CAN U TURN THE PROPELLER BY HAND
Mar 25, 2014 | Asko W6903W Front Load Stacked Washer /...
Printer Error AF
The flat cable of the scanner wasn't connected properly. Try to straighten the end using your finger nails , then slot in the connector. Try again. Good luck
Jan 20, 2014 | Brother DCP 130C All-In-One InkJet Printer
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore Oasis Canyon Capacity electric dryer has AF problem. Husband has removed back of dryer and can't find reason for lack of air flow. Dryer spins but no AF. Please help!
If you haven't checked the exhaust running through your home to the outside do so. Be sure that it is clear of lint and debris and if it is over fifteen feet then you may need a fan to help the flow through that venting. If none of that helps then it sounds like a defect in the machine.
Mar 14, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
OVERHEATING, AF CODE..... Whirlpool Cabrio WED6200SW1
Mine is doing the same thing. Whirlpool still has it under warranty but says they won't replace it. They will only repair it. They have been out 5 times now and still not fixed. It will work one time and the clothes are scorched when I took them out. Do NOT BUY WHIRLPOOL. I think we should start a civil suit against Whirlpool for replacement of all of these washers.
Apr 11, 2009 | Dryers
Turning af beam off
The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
Apr 21, 2008 | Canon PowerShot A520 Digital Camera
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Dryers Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
