Question about Samsung Televison & Video
Samsung model HL-85086W projection tv
The set will come on as soon as it is plugged into wall outlet. The picture will come on and start working but just for a few seconds and then it seems as the picture is frozen and I can't change channels, turn off or on, the power indicator led is off. The led that indicates reception of remote control signal still works. I do know that the light and power company has been working in the area before this occurred. The sound came on for about the same length of time as the picture. The screen was a full screen. I did notice that after leaving set on for a few more minutes that it tried to move the image on the screen just a little and then immediately freeze again. everytime i change the color on my to make it brighter it wil save for 20 min then go back to dark how do i save changes ??
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
Luvlee
  • 59 Answers
SOURCE: Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Posted on Mar 23, 2008
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Posted on Aug 17, 2008
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
My 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.
It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
Dec 12, 2012 | Samsung HL-67A510 67" DLP HDTV
TV stopped working samsung model UA32D5000PM
Check and replace its main system control memory IC. Before replacing it, just make a hard reset to this set. Unplug the TV from AC mains wall outlet, and re-plug it back after 1 minute or so. This must make the set a hard reset.
Sep 01, 2012 | Samsung Televison & Video
Where can i buy a transister for a samsung 50" dlp
you should be able to get any part needed from www.tvrepairworld.com
Sep 25, 2011 | Samsung Televison & Video
Tv shuts off and on by itself dlp 5064 tv only seems to do it when the tv is on for a long period also when the power is on the standby/lamp is illuminated
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. I
Jul 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv will not turn on
Check to see if there is a problem with the internal fuse. Your user manual should have a troubleshooting section that will address your particular symptoms.
You should also plug a different appliance into the outlet where your TV is plugged in to make sure there isn't anything wrong with the outlet.
Though this probably isn't the case, I have sometimes seen outlets that are controlled by a wall switch, and sometimes, the wall switch is accidentally turned off.
Jun 20, 2009 | Samsung HL-R5656W 56" DLP HDTV
Snowy picture
.u need to replace the tuner of ur tv set...its a technical work better call service technician
Jun 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Televison & Video Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
