Samsung HLM5065W replaced fan # 2 part number BP31-00024A. After reading these emails I gained confidence...I replaced the fan but have a small problem. After installing the new fan in its casing (with circuit board on it)... I cannot figure out where the VERY small 3 prong female wire plugs into. It is 2 whites and 1 blue on it and is much shorter than the black/red/yellow wire that comes out of the fan. I do not see any slot for this WWBlue wire to plug into. This wire comes out of a small barrel shaped part on top of the fan casing/circuit board. This wire was unplugged when I pulled out the fan casing assembly. If I had a schematic I think I could figure it out. Other than this problem I would be finished in 10 minutes. Samsung will not help and will not provide a schematic or a "snapshot" of this fan # 2. I did not take off the color wheel, etc. but I removed the lamp and then the fan housing (that looks like a speaker horn and has a circuit board on the top. I then took out the fan and replaced it. Please help!!!! Please SHOW me where this WWB wire goes. Can you explain and show me via schematic or pictur. I cannot afford to have a tech come out and finish a job that is 90% completed.
    Scholar:
  • 118 Answers
  • 10,594 Answers
You can buy service manual for approx $20 from online manual website. Service manual has all details about TV schematics, connectors etc.
Posted on Feb 08, 2009
  • 350 Answers
    Sergeant:
  • 326 Answers
Did you got the exact fan which is required to replace as if its different model it will be little bit different in wirings and connections.for furether help  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
Lamp and heat light blink
hi there
you have a fan problem close to the lamp
could be jam
Sep 30, 2010 | Samsung HLM5065W 50" Rear Projection...
Screen is black tv wont come on, power on lights flash
Replace Lamp ,Go to E-Bay lamp number is BP96-00224c, I just got one for $85.00.
Aug 20, 2009 | Samsung HLM5065W 50" Rear Projection...
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
Troubleshooting Problems
Just click below for the site links inside;
http://www.fixya.com/support/t935135-fan_failure
Hope it may help you;
Regards,
VOTIT
Sep 23, 2008 | Samsung HLM5065W 50" Rear Projection...
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Flashing
I am currently having the same problem. It started they way you are discribing, but now the TV will do that after the TV has been on for 20min and then will shut off within 30min. Then all the lights up front flash. I have replaced the bulb and that was not the problem. I also NEED HELP! Occasionally the picture on my TV will be inverted and sort of "dance" back and forth on the screen.
Apr 30, 2007 | Samsung HLM5065W 50" Rear Projection...
Televison & Video Logo
321 people viewed this question
Top Televison & Video Experts
