Question about Toshiba SD-4700 DVD Player
Changed HDMI settings and can't now see image on screen
I have a Toshiba SD-480ekb DVD player, stupidly I changed the settings of the HDMI scaling and it's now just displaying a blue screen. The machine isn't connected via a HDMI cable, it's only an old scart cable. I just want to know how to reset the machine to its original factory settings. If any one can help that would be brilliant.
Thanks
Terry.
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Posted on Feb 18, 2009
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
Toshiba sd-5000 just not playing. all HDMI cables are properly plugged in. Accidentally push a "strange button on the remote and the DVD player just topped working. The LCD shows that it is working, but my...
I got the same problem today. I thought it was a connection on HDMI cable problem. I tried many different options to solve it but nothing was working. After I read your post I realized that my 2 y old boy was playing with the remote before it happened. So I found on menu in DVD player option - default setting- and I pressed it - and bingo - it's working. I used cinch cables instead HDMI while I was fixing - just in case you cannot get the menu screen on tv - good luck
Jan 20, 2010 | Toshiba SD-5000
Attempting to play a DVD on a Toshiba player but not able to get full screen picture on TV. Can you help with the problem?
A DVD plays in "Letterbox" format. To have full screen, the TV settings need to be changed to full screen, or zoom. Found in the TV menu of most TV's.
Read ya
Z
Dec 31, 2009 | Toshiba SD-K760 DVD Player
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
Toshiba SD-480EKB DVD player
HD is not HDMI. An HD disc needs an HD DVD player.
Mar 19, 2009 | Televison & Video
Toshiba SD480E HDMI DVD Player will not play flash drive content
hi there!!! i have encountered a unit like yours ,, maybe this solution works,,,,,,if your unit has little reset button at the back panel of the player just push it,,, or in the system set up just restore the factory settings,,,,,,,, i hope that solution would help your problem
Jan 30, 2009 | Toshiba SD-4700 DVD Player
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Toshiba SD-4700 DVD Player Logo
356 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
