Question about JVC KT-SR2000 Radio
JVC KT_SR2000 Sirius Radio - Bad connection between radio & dock.
The left speaker channel output is low when balance is set to left speaker. If I give the radio a slight twist while its in the dock, the left channel comes in full. But once I let off the pressure of the twist, I loose the left channels full connection. Any suggestion how this can be fixed.
SOURCE: jvc sirus and ipod issues
I am having exactly the same problems. No sirius and ipod has to be turned up very loud to hear at all. The problem appeared suddenly friday night with no movement of accessories. It was working when I turned it off and wasn't when I turned it on a few hours later. I have checked connections and reset unit with no success.
Posted on Oct 02, 2007
  • 6 Answers
SOURCE: getting reset 8
Be sure to check and make sure that your option output is selected to other, and not cd changer, and reset the unit.
Posted on Feb 06, 2008
memturbo
  • 226 Answers
SOURCE: My JVC car radio/CD player only allows me to scan for stations
the manual can be found here
Posted on Mar 27, 2009
SOURCE: I have a jvc am/fm radio in my boat and can't get any sound
moh hook gi2332
Posted on Apr 19, 2009
  • 61 Answers
SOURCE: Left side crackling noise Blown channel?
Would check your balance settings. Make sure your not balanced more to left than right. Next i would try to swap over one of the speakers from right side to left to see if it crackles. If not replace left side speakers.
Posted on May 19, 2009
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
Display does not work
HI. I lost my code for radio ford focus serial number M227636
Feb 03, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver with...
I lost my code for radio ford focus, serial number V069241
Unfortunately the Ford V Serial Number codes are only available from the Ford Main Dealer.....................or a Decode Service who will plug your radio into a laptop and read/recode the memory chip
Sep 07, 2009 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Disassembly of JVC KT-SR3000
Did you get it open? remove the two screws. Those are all the screws on the outside. Gently pry the halves apart at the bottom of the unit. Gently try a flat screwdriver. GENTLY! Theres some tabs that hold the rest together. You may break one or two but will be ok in the end. Do the prying at the bottom so you dont break the tabs at the top.
Apr 09, 2009 | JVC KT-SR2000 SIRIUS Radio Receiver
LCD screen back light doesn't work
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality.
Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
Feb 20, 2007 | JVC KT-SR2000 SIRIUS Radio Receiver with...
JVC KT-SR2000 Radio Logo
35 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
