Question about Tascam 2488 Portastudio Multitrack Recorder System
Poor Recording Level on the Tascam DP-02CF
Just purchased this unit. When I go to record, I have to crank the levels up to max just to get the unit to register the input. I've tried different mics and connected a midi unit, all with the same result - I have to crank the levels. I do get a recording and can play it back, but obviously this isn't right...and the sound quality isn't great. Anyone else experienced this with the DP-02CF? Any help would be greatly appreciated!
  • 1 more comment
  • maxfield Feb 23, 2009
    pretty much the same as described. Anyone find an answer yet? If I find one, I'll be sure to post it.
  • ElleMTee Mar 28, 2009
    I have the same issue...and it's annoying because most of the tracks are cool - except the bass distorts because it's obviously red-lining...I hope someone can point out a simple solution :)
  • Gilbert Lane Aug 03, 2015
    Check your Input Trim levels. That's where it all starts.I have a DP02 (with the CD burner) and after running through my mixer, I then run that output into the unit. Check those first, mine are at about 75% of max. (They're the two knobs at the top of the board) Try it, I had a similar problem, when I got mine in '08 but after turning the input trim up, I've had no problems. Also remember any "passive" instrument, guitar, bass, even dynamic mics, aren't very loud on their own. That's why we have amps, and mixers, etc. Try running your equipment through an amp, (using the line out, or effects out [if you don't have a line out] before going into your unit. This goes for mics, keyboards, guitars, etc, unless you have a ribbon mic, then use the 48v Phantom power, on your mixer, or on the unit. It will make a world of difference. I found this out with my old, TASCAMPortastudio 1, cassette recorder, many years ago.
    New Friend:
    Problem Solver:
  • 12 Answers
If it works like my DP02 and DP03, you must disengage the tracks you've recorded to, get it to playback. Also make sure your Master Fader is turned up as well as the faders for the tracks you've recorded. Also on the Inputs Trim (the two knobs at the top) should be at least 50% up. I have my Dp02 at about 75% of max and my DP03 at 50%. Try this if it doesn't help, customer service at 323-727-7617 or 323-726-0303.
Posted on Aug 03, 2015
I had that problem too at first, and i turned on the "phantom" option and its worked wonderful ever since.
Posted on Apr 24, 2009
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Posted on Mar 17, 2009
When I burn my mastered tracks to CD, the volume is so quiet it can hardly be heard at all. The sliders are up almost full.
I believe you need to install an BBE Sonic Maximizer to boost your signal recording before your DP-02
Jul 13, 2011 | Tascam Dp-02cf Digital 8-track Recorder
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
DP-02CF Exports files to PC, but reads no file found when importing wav.
The answer is in the troubleshooting section of the manual:
Page 53:
"Why can't my computer "see" the unit files"
Mar 01, 2011 | Tascam Dp-02cf Digital 8-track Recorder
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Im looking for a manuel for my DP-02CF;9,16,3580,19.html
Go here and under the picture of the unit is a free download of the manual. Good luck
Feb 08, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Tascam 2488 Portastudio Multitrack Recorder System Logo
392 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
