Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby is smoking and breaking belts
My kirby is smoking when I try to shampoo the carpets. It burned through two belts. One was an older belt, the other was brand new. I hooked it up just exactly the same as I have before and dont understand why its doing this and dont want to waste more belts. Can anyone help?
First thing , make sure that the roller brush is turning freely.. should spin like a top.. free and easy, if not that is the problem
the bearing on the ends are seized up and it isnt turning and you belt is turning on the motor shaft, thus causing the smoke and burning
WPVAC
Posted on Feb 11, 2009
I've broken 2 belts while shampooing the carpet this time, never has happened before, what am I doing wrong.
If you have plush carpet, the brushes on the vacuum may be catching on the carpet, causing the belt to slip, overheat and break.
If the vacuum has a height adjustment, try adjusting it to a setting which lifts it higher off the carpet.
I hope this helps!
Good luck.
Jul 13, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have a very old kirby generation 3 unit that converst to a carpet shampooer. I was attemtping to shampoo the carpets but it does not seem to be picking any of the water back up out of the carpet. What...
make sure the belt on the carpet shampoo aggitator is good, (could be stretched or broken) recommend replacing that belt. also make sure your fan in the front of the machine doesnt have any chips or cracks around the center. (this will cause lower suction) a new belt should cure the problem for you.
Jan 06, 2010 | Vacuums
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Belt broke on shampooer
there are screws on the ends. I got it fixed.
Apr 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Sep 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Vacuum brush roller with belt attached is off
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
228 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
