Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Mix spark wire on my v6 4.3 dist cap 1500 chevy
I replaced my dist cap and mix up my wire on my dist bout a aftermarket cap need to know is the no#1 on dist cap
    Brigadier General:
  • 5,158 Answers
1-6-5-4-3-2
Posted on Feb 08, 2009
WEAK SPARK AT PLUGS
That truck should have no points. It should have electronic ignition. Sounds like bad wires or bad coil(s).
Apr 25, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
1 clyinder misfiring
It could be one or both of the items you discussed. In addition, did you change the rotor when you changed the cap. If the cylinders have individual coils the coil could be weak as well.
Jan 01, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Shaking
I take it that it shakes when the engine is running but the transmission is in park. You will need to locate which cylinder is not firing. If you have a thermo thermometer, you can check the temperature at the exhaust port for each cylinder. The one or ones with the lowest temp are not firing. Pull them out and see if water in on them. If so you have a head gasket or head problem. You can also , while the engine is running, pull the plug wire out of the dist cap one at a time to see which cyl is not firing. Be careful not to get shocked by using insulated spark plug wire pliers.
May 01, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
1997 chevy 1500 pickup won't start
You need to check if it is a spark problem or a fuel problem. Check to see if you have spark to the plugs by removing a plug wire from the dist cap, hold it 1/2 inch from the tower in which you pulled it from and have someone crank the engine over. If you have a strong spark, then it is a fuel problem. Take off the air cleaner and squirt some starter fluid into the throttle body. If it starts you have a fuel problem. Check the fuel pressure with a pressure gauge. Should have 45-50 psi depending on engine. If you have no pressure check the fuel pump fuse in fuse box. You may have a bad pump. You might try tapping the lowers part of the fuel tank with a hammer while someone else is cranking the engine over. Sometimes that will jolt the pump into pumping.
Apr 21, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
My 97 chevy pick has a random missfire
Possible plug or wire. At night in a dark place, have the engine running and spray, from a water bottle, the plug wires and around the spark plugs. If you see a spark, you found the problem. If no spark is found you will need to pull each plug to see if one is fouled out or not firing. To test the wires check them with an omp meter. They should have 4000 omp resistance per foot length. Possible crack in dist cap.
Apr 18, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
1997 chevy 1500 z71 cylider 1 misfire
Start by inspecting the spark plug. If it looks ok, swap it with another cyl and see if the miss follows the plug. Do the same with the wire. If the miss changes with the part, that is the problem. If it stays with the cyl make sure you are getting spark from the dist cap. If the miss is still there, check engine compression. If it is good, may have a bad injector or mechanical problem or vacuum leak
Feb 17, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Ignitin module on 1997 chevy 1500
1. Take off dist. cap
2. take off rotor
3. disconnect the 2 wire connectors from module.
4. Unbolt 2 screws holding module to dist housing.
5. Replace old module with new one making sure you use heat gel on new module (gel included with module)
Good Luck
Jan 08, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Weak spark at plug
Check to see haw strong the spark is coming out the dist cap. If it is weak there, possible bad cap/rotor/coil/ module. Make sure the wire from the coil to the cap is good.
Jan 01, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
97 chevy 1500 4x4 4.3 wont start when wet have changed cap rotor plug wires plugs. veh has spark and fuel!
I have the same problem with my 1998 chevy 1/2 ton, if the weather is damp we have to plug it in, give it an hour and away it goes, have had it to a shop several times and still no solution. we have also changed cap, plugs plug wires
Aug 26, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
Where is the ignition module on a 1998 chevorlet pickup k1500 5.7l?
where is the ignition module on a 1998 chevrolet pick-up truck k2500
Jul 18, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
98 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
