Have a compaq Presario SR1810NX will not boot up
Moitor comes up, tried F1 & F10. Even the recovery disc won't budge it.
  • DEKR
    DEKR May 11, 2010
    please give me more info
    have you changed anything or upgraded
    or added new memory
  • kolrar May 11, 2010
    After powering on the machine does it get to the POST test screen? Do you hear any beeps from the machine at all? Does it fail to get to the XP splash screen, or does it blue screen, or is there just a black screen from start with no BIOS info etc displayed? Are ANY error messages displayed at any point of the boot, and as the other person has asked already, have you opened the pc up and messed with any of the hardware yourself?
When you power it up it just shuts down no power at all?
Posted on Feb 22, 2009
    Problem Solver:
  • 11 Answers
Try shift f5
Posted on Feb 12, 2009
Compaq Presario pops up a system boot menu everytime at startup.
This comes up mostly when it requires a BIOS save. Try that. If that does not help, sometimes setting the default settings and saving will help.
Dec 04, 2012 | Computers & Internet
My HP Compaq Presario sr1610nx hangs at the Compaq screen. I won't boot Windows and does not respond to esc F1, F8, F10 or the recovery disk 1 CD. I tried replacing the RAM sticks and the battery...
Try clearing CMOS. Take the battery out and press and hold the power button for 30 seconds. If that doesn't work disconnect or change out drives and memory one by one until you find the reason your pc won't POST. Once you can at least get to BIOS you've found your problem.
Jun 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
Compaq sr1500nx reads NTLDR is missing
boot from your install disk and open CMD, from there use /bootsectit will give you your options
May 03, 2012 | HP Compaq Compaq SR5502FH-E Presario...
Why does my compaq presario SR1810NX turn off immediately after turning it on ?
Beep sounds indicate a hardware problem, check you RAMs, remove them and air blow the RAM + its trays on the motherboard then try to boot up again.
Feb 20, 2012 | HP Compaq Presario SR1810NX PC Desktop
What do my recovery discs say on them or look like for my hp sr1720nx and how many do i need.
some recovery comes in a partition on hard drive and it can be activated thru start up screen
bios....recovery....avanced boot like press f2 to bios...or f10 to recovery
May 25, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
I have a compaq presario 5600 / P4-1.5G/128MB/40GB/C48/M The other day the system hung, and nothing was working. I changed the CPU battery, cleaned the dust. the system started with Intel boot agent 4.0...
You probably need to set your boot order in BIOS (setup) to load from CD first. Reboot the computer and press either F1 or F10 repeatedly until the setup (BIOS) menu comes up, then, using your arrow keys, navigate to the boot menu and set the boot order to CD first.
If you can't get into the BIOS through F1 or F10, try other "F' keys until you get in. Also the "Del" key.
Recovering to factory settings is kind of a drastic measure just because of a system hang. You would be better served to find out why the system hung. IN FACT, understand that depending upon what is wrong, the system may hang during the recovery, leaving you with fewer options for repair.
Post back if you want to try to troubleshoot this further. It will take a while, but we should eventually be able to determine what is causing the hang.
It could be just an application that needs to be removed or re-installed. Have you installed any new software recently? What software were you using when the hang occured? What operating system are you using?
It could just be a virus or a bad memory module. Are you able to boot into SAFE MODE" (press the F8 at boot)?
If you can boot into Windows, go to "Start" > "Control Panel" > "Administrative Tools" > "Event Viewer" > "System" and check for any error entries. Also look at the "Applications" log.
Aug 15, 2010 | HP Compaq Presario PC Desktop
Compaq presario doesnt boot upon powering up
boot into the bios or if bios support diagnostics boot into that (typically F1 of F10 on power up) If that is not an option boot off the CD recovery disk and run diagnostics on the HD. Let me know we can take it from there.
Jan 30, 2010 | HP Compaq Presario SR1830NX PC Desktop
Restoring factory setting
you should have received some discs when you bought the PC...if not, try looking in your programs list for the application to create the Recovery discs.
Some, not all Compaq's have a F10 recovery (at boot press F10)
be sure to save your personal data to another source (USB stick, CD...etc)
Feb 02, 2009 | Compaq Presario R3000 Notebook
I purchased a Compaq Presario (SR1810NX) in April 2006. Word software was factory installed. A few months ago, the word icon disappeared. I tried to update it on the Microsoft website and my entire...
You most likly have to format the hard drive, and completely clean out the hard drive and re-partiotion, and then install the recovery disc.
Aug 01, 2008 | Computers & Internet
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
