Question about Kenmore 24032\24036 Top Load Washer
Leaking water under washer and off balance? What's wrong?
  • 1,902 Answers
You have two problems the more major problem is the water leaking. If this happens when the machine is filling then replace the water inlet valve or hoses going to it or to the tub itself. Next for the unbalanced part if it is the tub. Then check the bottom pulley and make sure that it is not bent. If it is the machine itself then the feet on te bottom of the machine screw in up or down and that is how you level your machine. If this has helped you please rate. Thank you
Posted on Feb 12, 2009
After every wash I have to center the basket or it will cause leaking while filling up with water for the next wash. Why won't the basket stay centered. This has never happened before. Thanks
Hum sounds like a bad thrust washer on the agitator spindle but that should not effect water overflow? may be wrong and it could be a bad water pressure switch, if it does not detect water level it can allow an overfill? check with a multi meter for continuity. if u mean the basket is leaning in 1 direction to low then u may have bad balance counter weights or the metal has corroded and the drum cannot be held firmly when under pressure.
Sep 23, 2014 | Crosley Washing Machines
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
On spin cycle water leaks from under the washer all over the floor
First thing is to make sure the washer is level and balanced, use the screws on the bottom and a level. Once level run and see if leaks. Also move closer if possible to the place the water drains to(or is supposed to drain to). If there is know leveling screws check manual to get part number to order, but first check other solutions as not to waste cash on screws you don't need.
Jan 31, 2010 | GE WBSR3140DW Top Load Washer
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Machine is usually very noisy ( like it was out of balance, but isnt) 90 percent time very noisy in the final expell of water, also some oil on the floor under center of machine ? this is a top load...
oil on the floor means your gear box is leaking
if it has been leaking. if it has been leaking for a while, it may have done major damage,and would be cheeper to replace the machine second hand than to fix.
if noise is happening while you are pumping , it may have a bra under wire or small coin in the water pump.
if it is sounding like it is out of balance it may have a support or spring broken or unhooked
as the tub is usually suspended by springs
May 05, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Washer leaking from bottom
Take the front panel off of the washer, and run it through a cycle. Watch to see where the leak is coming from. Also, pay attention to the drain in the wall when it is in spin/drain. If this has a blockage in it, it might be backing up causing water to come back out of it.
If you see no leaks the next time you run it, it's possible that it splashed over while spinning because of the off balance load and may not happen again unless it becomes off balance again.
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
