Question about HP PSC 1610 All-In-One InkJet Printer
Hp 1610 won't scan says I need to install or run device software. I am not sure how to do this. I have uninstalled the software and reinstalled it. Still not working what am I doing wrong
  • 4 more comments
  • Anonymous Feb 10, 2009
    I have exactly the same problem .-(
  • Anonymous Feb 12, 2009
    efff
  • Anonymous Mar 10, 2009
    same thing
  • Anonymous Mar 16, 2009
    ditto!
  • Anonymous Mar 18, 2009
    At least I'm not the only person with this problem.
  • Anonymous May 02, 2009
    same thing...someone help
5 Suggested Answers
BARRET
  • 21 Answers
SOURCE: Scanner issue on the HP 1610 all in one
Hi, Let me explain you the real cause so that when ever you face this issue with any printer you will be able to fix this in quick time. The scanning needs Bi-directional communication and as you are able to print and scan from the computer software fine this shows that the software part of scanning exe file is working fine. Please try to scan from software and if this works we have to next check for full feature HP software is installed in the computer. If you are able to scan fine from HP software check for the DIGITAL IMAGING Monitor Icon it will be a green icon in the system tray in the right corner of desktop this icon must be present to enable the scan from front panel scan button. If the icon is there right click on it and exit it and then search for hpqtra08.exe file in the computer if the file is found double click on the application file to get the icon back running on the desktop. Once done try to scan again from the front panel scan button and check if the issue is resolved. If the Digital imaging monitor icon is not on the desktop system tray search for the file hpqtra08.exe in the computer and excute the application file . Even if the icon is there and you are not able to scan from the scan button we have to set the settings in the HP software In the HP director click on settings >> scan settings >> scan to button settings there click on the Destination list button this will open a small window with Two boxes 1)Available scan list 2) front panel scan to list all we have to do is to move all the programes from the available scan to list to front panel scan to list by selecting each program and click on add to move it to right. Once done do not forget to save the settings click on OK to save the settings once done try to scan from scan button this should fix the issue. The Digital imaging monitor icon or Hpqtra08.exe file should be running to enable the scan function from the scan button ... I hope this will help you in solving the all the issue in future related to scan butto not working the same steps applies to NO SCAN OPTIONS message on printer when you try to scan ..... Regards, Barret.....
Posted on Sep 27, 2007
  • 3 Answers
SOURCE: HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Posted on Feb 04, 2009
SOURCE: this error will not stop coming up on my computer
Navigate to C:\Program Files\HP\Digital Imaging\bin
or C:\Program Files\Hewlett-Packard\Digital Imaging\bin
Double Left Click on the executable file:
hpqdstcp.exe
You will NOT see anything happen but it will get your program destinations setup correctly and hopefully remove the error. This sometimes happens when you change printers and old stuff stays on your PC.
Hope this helps.
Posted on Aug 30, 2009
  • 105 Answers
SOURCE: unable to communicate with HP scanning software
This happened to me a couple times with the HP Series all in one and stand alone scanners. Goto Walmart and buy a USB hub that has a dedicated power supply. For some reason HP is notorious for this problem.
Posted on Oct 17, 2009
I have changed printer but I could not unistall HP 1610 from my Control Panels - Program Maintenance.....
Hi simoncsi,
I see you cannot uninstall you HP 1610 printer from your machine.
Possible that the software is experiencing problems try reinstalling over the existing software then try uninstalling again.
If this does not work then try downloading CC Cleaner here just save the file or you can just run it from online to install directly, this is like the windows Add remove program you will see all the programs installed on your machine just look for HP 1610 on the list and select uninstall.
This should uninstall the HP 1610 software from your machine.
I hope this helps.
Have a nice day,
mvincentc
Jul 08, 2011 | Computers & Internet
The issue is as follows: I am using an HP Officejet 7310 All-In-One. My computer is a Mac using OS 10.6.5 Snow Leopard. The Print, Fax, and Copy functions are working perfectly, but I cannot get it to...
Click on the link below and download the latest software for your printer.
Driver Download
Uninstall the existing software and download the latest driver and install. it should work fine.
Regards,
Shawn
Feb 05, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
Sounds like you need to install, or reinstall the scanning software on your computer.
Select your OS on this page, and you should be able to get what you need: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=390315&#
Mar 21, 2010 | HP PSC 1610 All-in-One Printer, Scanner,...
Scan will not work
Step one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon (c01387841.gif ) normally appears in the Notification area at the lower-right corner of the computer screen. The monitor is ready when a check mark appears on the icon after you start the computer. If the Digital Imaging Monitor is in the system tray, skip to 'Step two: Populate the Destination List.' If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software. Click here to go to Step three: Uninstall and reinstall the software .
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to fill out the destination list.
  1. Open HP Solution Center with one of the following methods.
    • On the Windows desktop, double-click the HP Solution Center icon (c01425508.gif ).
    • On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after you turn on the printer or computer.
  6. Click each program to include on the Scan To list.
  7. Click the Add arrow.
  8. Click OK .
  9. Scan a document using the Scan To button on the front panel.
    • If the scan fails, try to scan using the HP Solution Center Scan button.
    • If the scan still fails, continue to 'Step three: Uninstall and reinstall the software.'
Step three: Uninstall and reinstall the software Uninstall the software
  1. Unplug the USB cable connecting the product to the computer. CAUTION: Do not reconnect the USB cable until the on-screen instructions prompt you when you reinstall.
  2. Click Start , click Control Panel , and then double-click Add or Remove Programs .
  3. In the list of installed programs, click the HP product, and then click Remove .
  4. Follow the on-screen instructions to complete the software removal. NOTE: If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
Reinstall the software
  1. Turn the product on.
  2. Open a new window to browse to the Select Software and Drivers page:
    1. Right-click this link, Select Software and Drivers , and then click Open in New Window .
    2. If prompted, type your product number. You might also need to click it in a list of similar products.
    3. Click your operating system. (If you do not know, click Start, right-click My Computer on the menu, and then click Properties .) The Select Software and Drivers page opens.
  3. Click the Full Feature Software and Drivers option.
  4. Click Download only . This option allows you to install the software at any time after the download completes.
  5. Click Save , and then browse to the location on your computer where you want to save the file.
  6. Click Save . The software downloads to your computer.
  7. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe
  8. You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  9. When the Install Wizard starts, follow the on-screen instructions to install the software. Important : If you choose a Custom type of installation (available for some products), make sure to install HP Imaging Device Functions so that you can scan from the printer. The Recommended installation type installs this feature automatically.
  10. After successful installation, scan a document
May 08, 2009 | HP Photosmart 3110 All-In-One InkJet...
Unable to install SCAN functions for HP PSC 1610
If you are having issues using your PSC 1610 on the Vista operating system there is actually an easy workaround using "paint" (I'm using "SnagIT").
Check it out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&product=390315&lang=en
For whatever reason you can't use the actual button on the printer/scanner but when you open paint you can scan the doc from your computer.
Hope this helps!
Mar 27, 2009 | HP PSC 1610 All-In-One InkJet Printer
My HP 1610 printer works, the copier works but when I try to scan it says "No scan options" need to install or run device software. Don't have the disk we had a flood 9/14/08 and everything lost in the...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
Our scanner wont work the printer and copier work fine
You should be able to find a white sticker on the bottom of the printer. The serial number will be there as well. If you have the PCS 1610 than follow the uninstall instructions given by Hp at this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265838&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en
Than go to the link below and download & install the 1610 software: HP Full Feature software/driver: No Network Support &
HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch
That should fix your troubles. Look at the fixes while at Hp and if you feel you need other upgrades now would be a good time to download.
Dec 29, 2007 | HP PSC 1610 All-In-One InkJet Printer
Flashing display
It is very important you follow ALL of Hp's instruction at the link provided below for uninstalling your PCS software. Than go to the bottom of the link and also follow the instruction to run the uninstall utility called "Uninstall.bat"
Reinstall your driver software from Hp's download site. (these are updated drivers).
Most of the time its a good idea to follow the instruction during installation.
Dec 25, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
471 people viewed this question
Ben Johnson
