Question about Sanyo DP23625 23 in. LCD Television
TV shutdown My new Sony 32" HDTV only shuts down to a dark blue screen. I expected it to turn off completely. A TV salesperson told me this was normal. I can't accept that.
As it was a new purchase, I returned it to the store!!!
Posted on Feb 10, 2009
The whole screen turned blue while shifting it to get to inputs. Now I can't get anything but a blue screen.
If you have not turned the TV off yet then do that. Turn it off and let it power down completely. If it has a fan then let the fan stop spinning. Wait about 5 minutes then turn the TV back on. If you still see blue then you may need a new bulb or the light engine in your TV has gone bad.
Feb 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
We purchased a sony wega hd lcd projection tv. The set had a great picture until the lamp had to be replaced. The screen got progressively darker until the screen went completely dark. After the lamp...
It sounds to me like you got a fingerprint on the lamp when you installed it. The oils in your skin can cause all kinds of problems on a lamp that gets soo hot. I recommend replacing the lamp again and using a tissue or sterile glove to hadle the new bulb. Also, before replacing the lamp make sure to clean and vacuum out the light engine box and fan.
If the problem persists, then the LCD panels inside the light engine have been heat damaged. There is a class action lawsuit in New York that is trying to extend the light engine warrantee on Wega TVs. You should give Sony a call at 1-800-222-SONY for information and more assistance.
good luck!
Dec 03, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Sony goes blue
you need a new Blue CRT you can get them at the following link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
regards,
daniel.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sanyo DP23625 23 in. LCD Television Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
