Question about Vornado TouchStone Vortex Heat 500 Heater
Fan shuts down, shortly after heater is turned on
TouchStone Vortex Heat 500 Heater, heater less than a year old.
  • gertas Feb 11, 2009
    First of all I have 2 Vornados. They are both model # EHI-0005 which I didn't see on your choice of model numbers. They were both rebilt in 2004 per a recall. I am having the "Fan shuts down, shortly after heater is turned on problem" on both of them. We have tried them both in different plugs and different rooms and still have the same problem. If there is nothing we can do to prevent this, we would be willing to send them to you for repair if the cost would be within reason.
    Thank you, Carol
    Gerta's Draperies
I have a Lennox furnace that starts but won't ignite.
Turn up the thermostat, you can hear it start but the burners don't come on
Posted on Feb 10, 2009
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
Oct 22, 2010 | Vornado TouchStone Vortex Heat 500 Heater
The heater is turned on. All lights are on. The fan isn't running. No heat is coming out. It was working earlier in the day.
did it get set on its side, there is a saftey switch inside to kickout the heating element if its knocked over, unplug it, pick it up and turn it around at different angles, return upright, shake gently, plug in and see if it puts out heat
Jan 31, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Internal fuse blown as well as a capacitor, where can i get repaired or parts to make repairs
an electrical supply store would be the place to start. take the old parts with you as they have to have numbers off the old parts to get you the right replacements.
Jan 10, 2010 | Vornado TouchStone Vortex Heat 500 Heater
How to install programmable thermostat
If it is a wall furnace with a built-in thermostat(sounds like the 1 to 10 dial is the thermostat) into the control then you would need to buy an updated gas contol valve that will hook up to an external thermostat and a programmable thermostat. The old gas contol valve would need to be removed and the new one installed. Then the thermostat wires would connect to the gas control valve millivolt system. A heating company can perform this service for you and I highly recommend you have it professionaly installed if you are not experienced on this process. You could leave a gas leak or other hazardous situation if not installed correctly.
Nov 18, 2009 | Vornado TouchStone Vortex Heat 500 Heater
Lg window-type ac
Most little window units are mainly for 300-500 Square foot rooms.
Should be putting around 80-105 degrees top out of those little units, Make sure that your thermostat is set for heat rather then the normal setting of cooling (Turn more towards Heat) also if you have a fan setting you may want to try lowering the fan to low speed vs high fan, which should give you more heat.
Make sure the Filter is clean as well as the coils behind the filter or it will shut down the heaters quicker due to lack of air, shutting down your T-stat and bi-metals quicker.
Nov 11, 2009 | Heating & Cooling
Electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Jan 09, 2009 | Heating & Cooling
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Vornado TouchStone Vortex Heat 500 Heater Logo
853 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
