Question about RCA HD52W59 HDTV Projection Television
Fixed but not fixed
Replaced FL230,CL203 and DL231 after i replaced the fl230 fuse tv was working fine.I was told to replace the other 2 fuse so i did.Now the tv shut`s off and on and my coverce is gone
  • DrjRepair Feb 19, 2009
    I replaced the FL231 fuse and it blew again. Since I have to order it should I order the CL230 and the DL231. While I am waiting I wan to resolder the Flyback do I need to remove the Two Red Wires from the unit or is it OK to leave them connected?
    Thank You for your time
    Problem Solver:
  • 9 Answers
The three fuses are not the same ones. Sounds like you used the incorrect fuse for FL231 (middle of the three).
Posted on Feb 09, 2009
Will not turn on
If you replaced the FL231 without replaceing the DL231 it will usually work for a little while then fail. However if the sound youre hearing now is a short sharp chirp which coincides with the power indicator its often caused by a failed flyback and HOT Transistor, if the sound sounds like a soft psssst three times then DL030 and DL032 all items are on the Deflection/power board.
Jul 18, 2010 | RCA D52W19 52" Rear Projection Television
Hd52w59 Convergence - DL231 replacement
DL231 is a fast recovery diode and should only be replaced with another MUR160 diode.
Mar 01, 2010 | RCA HD52W59 HDTV Projection Television
R56WH78 RCA TV Power/Deflection Board
Did you resolder the Flyback and replace DL231 and CL230 with the FL231?
Jan 07, 2010 | Televison & Video
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
I have a Philips plasma 50 inch tv, I had the red dot problem a year ago. Went through the extended warranty and Andulusia TV service in Bensalem, to repair the problem. They had it for amonth and told me...
the panel is bas. it has a diffusion problem.most extended warranty companies require you to let the shop try 3 times to repair for the same problem. on the 4th time they talk replacement.
best to read the contract.
Dec 17, 2008 | Televison & Video
Philip 50 inch plasma-red dots
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Televison & Video
56"rca hd tv blowing fl231 convergance fuses
replace DL231, CL230 , Fl231 then reflow the solder on the Flyback and vertical IC and that should solve the problem. You can get replacement parts at the following link .
Nov 26, 2008 | Televison & Video
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
RCA HD52W59 HDTV Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
