Question about Toshiba Satellite Pro A10 Notebook
How to replace dvd rom drive.NO release button on base!
Toshiba Satellite pro A10 Model no.PSA15E-01PFQ-EN.Trying to replace faulty DVD/CDRW drive.Previous answer said release button on base,but not on this model.
How to disassemble?
  • eddavis144 Feb 08, 2009
    There is a screw under the keyboard.Remove keyboard securing strips & turn it over to access the DVD securing screw.
Firstly there is a screw on the underside of the laptop that needs to be removed.I ts is located on the edge of the drive.
Next the keyboard needs to be removed. To do this, remove the strip at the top of the laptop containing the power butto by inserting a small flat blade screwdriver at under it and prising it up.
After removal, undo the three screws holding the keyboard and flip the keyboard over.
Undo the screw that holds the keyboards strap securing plate and then slide the drive out.
Be warned though that not all drives work in these laptops. It has to be the exact type for the machine as most do not work.
Assembly is the reversal of the above.
Hope this helps.
Posted on Feb 20, 2009
Use a allpin and insert it near the switch in DVD Rom press it gently tray will come out bye and take care
Posted on Feb 09, 2009
ATOSHIBA SATTELITE PRO A10 MODEL PSA15E-01PFQ-EN SET-UP DISC?
You can download the device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Nov 03, 2012 | Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          What is the drive type used in the Toshiba 2415 S205 laptop?
          Specifications of TOSHIBA Satellite? 2415 Series
          P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
          Satellite 2415-S206
          P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
          Performance
          Mobile Intel® Pentium® 4 processor-M at 2.00GHz
          Memmory 256MB expandable to 1024MB
          All-in-one design
          40GB* hard disk drive
          DVD-ROM/CDRW multi-function drive
          Mar 15, 2010 | Toshiba Satellite 2415-S205 Notebook
          HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
          You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
          Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
          Toshiba dvd rom
          Toshiba Satellite 1400 Series DVD/CDRW Combo Drive (P000347430)
          hope that helps
          Jun 11, 2009 | Toshiba Satellite A105 Notebook
          I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
          Hi Packman,
          right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
          . but I´m sure you´ll find it.
          regards
          /Teis
          Dec 16, 2008 | Toshiba Satellite 2805-S301 Notebook
          Cd/dvd rom
          HELLO. IT SOUND'S LIKE IT COULD BE A COUPLE OFM THING'S MAYBE.? THE FIRST THING IS TO SEE IF . ON YOUR DESKTOP . IN (MY COMPUTER) SHOW'S YOUR DEVICES WITH REMOVABLE STORAGE ... DVD/CD-RW DRIVE WITH A LETTER...LIKE (D:) OR (E:) THEN YOU NEED TO OPEN THE PROPERTIES ON IT.!!!! AND YOU THEN NEED.!!! TO GO ARCROSS THE TOP OF THAT PAGE TO WHERE IT SAY'S HARDWARE AND CLICK ON IT. !!!I IT WILL SHOW YOU HARD DRIVE AND SHOULD SHOW YOUR DVD/CDRW.!!! THEN YOU NEED TO CLICK ON IT.!!! AND OPEN IT.!!! IT WILL SHOW THE PROPERTIES OF DVD/CDRW.!!! AND TELL YOU IF IT IS WORKING PROPERLY.!!! OR NOT.!!! IF NOT YOU NEED TO REINSTALL THE DRIVER'S .!!! FIND THIS OUT AND GET BACK TO ME AND LET ME KNOW.OK.!!! "GOOD LUCK"
          Jan 19, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
          Toshiba A30 - DVD-ROM CDRW
          Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
          May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
          Removing the DVD-ROM drive
          hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
          Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
          Toshiba Satellite Pro A10 Notebook Logo
          270 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
