Question about JVC HD-56G886 56" Rear Projection HDTV
I am trying to connect my Wii and Wii fit.
I can't find the correct input for the Wii to connect. I have a JVC model #HD-61Z886.
My wii fit came wireless. You have to wait until the update loads and then it will walk you through it with directions. Don't try and do it before because it won't work, we tried.
Posted on Mar 13, 2009
    Problem Solver:
  • 13 Answers
Well there should be a composite connection ( yellow, red, white) on the back of your set labeled with a input name. just plug it in to that and use your remote to cycle through the different inputs. it deffenitly helps to keep the Wii on so you dont miss the input
Posted on Feb 08, 2009
JVC HD-61Z886 61 picture is dark. Is this fixable.
Could be dust in your light engine or build up on your mirrors.
Jun 21, 2012 | JVC HD-61Z886 61" Rear Projection HDTV
Lamp needs to bereplaced,,,,, tv jvc model 61z886, need to know model of lamp i need and where to buy it
Google "DLP lamp" and you'll get many places from which to order lamps. Go to one of these sites and they should have a search box. Enter your model number and it should give you the part number of your lamp. Try several sites if the first one doesn't give you what you need to know. Once you have your lamp number you can shop the various sites for the best price. Note: You can buy your lamp complete (with the housing it comes in),..... or just the bulb and replace the bad one in the housing (cheaper)..... if you have the skills needed. If not buy it complete with housing. If you change the bulb only,.. don't touch it with your bare hands. Most bulb only packages come with rubber gloves.
Aug 24, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
I have a shadow in the center toward the bottom of the screen of my jvc hd-61z886 projection tv
Clean the lense on the light engine. If ther is a door on the side you can put a microfiber rag on a stick and clean it. If not you have to pull the light engine and clean the lense. Be syre to unplug it and never turn it on with the back off. There is a sensor that will cause problems with the HDMI. If that doesn't fix you will need to replace the light engine.
Nov 04, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
I have a green hue to my jvc hd 61z886 61 rear
Hi
More than likely the lamp ,go to JVC website and get the part number for your lamp,google it and all the suppliers will come up,usually easy to change for customer and may be in your operation manual "how to"
Jun 04, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
How to replace bulb
Hi, i have retrieved your manual. it has all instruction on how to replace the bulbs. Click here for your manual.
A fix ya rating would be most appreciated. Thanks:)
Mar 05, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
Hdm ps3
Have you went into the video setup on your ps3 and changed the resolution to 1080p?
Dec 19, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
Jvc hdmi????
Do an EEPROM reset and will be ok.
Dec 11, 2007 | JVC HD-61Z886 61" Rear Projection HDTV
Hdmi cable not working
You have a bad main board it sounds like.
Jan 06, 2018 | JVC HD-61Z886 61" Rear Projection HDTV
JVC HD-56G886 56" Rear Projection HDTV Logo
697 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
