Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica Minolta CF3102
NEED TO RESET PASS CODE
    New Friend:
    Problem Solver:
  • 9 Answers
Hi, The basic code is 0000 , that get's you into the admin mode of your printer unit.
Posted on Jul 20, 2015
    New Friend:
  • 97 Answers
You can over ride the password from tech rep mode.
Take a look here for details on this machine.
Posted on Mar 26, 2011
  • 167 Answers
If it is the Admin password that is needed to be reset you CANNOT! You need to find out what it is to change it.
Posted on Jan 08, 2008
SOURCE:
My Konica Minolta Cf3102 gives me the machine status error P21 ? What does it mean and how can i reset it?
REGISTRATION ISSUE COLORS NOT ON TOP OF COLORS. You need to run the color registration procedure in service mode. requires print out to be looked at,
P codes will allow you to use the machine put degraded. Are your prints coming out with colors not on top of each other?
Try this site for the manual.
Service manuals electronic components datasheets and equipment schematics...
if the procedure does not work you mite have a bad regrestration assy which located under the transfer belt (Where the handles are for the belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 20, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Resetar unidade de imagem cf3102
DO NOT UNDER STAND?
Jun 27, 2012 | Konica Minolta Minolta CF 2002 3102...
Can you help me with a manual for a Konica Minolta DiAlta Color CF3102?
Here is the user manual from the Konica/Minolta web site:
http://kmbs.konicaminolta.us/productsattachments/manuals/OpsAdminNEW.pdf
If this answer was useful for you, please rate with 3 or 4 thumbs up, since 1 or 2 thumbs-up are for less than helpful answers.
Thanks for using FixYa and Happy New Year!
Jan 05, 2011 | Computers & Internet
Cf3102 Stapler issue
There is a sticker on the finsher normally located on the side of the finisher againist the copier. if network then check properties of the printer when you select printer on the computer.
Mar 18, 2010 | Konica Minolta Office Equipment & Supplies
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
REQUIED WEB FOR KONICA MINOLTA SCCANER CF3102
Here's the link your looking for :)
http://onyxftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileid=12417&productid=457
Google is Your friend, Just run the setup.exe leave the usb lead out of your machine until after the installation.
Jan 29, 2009 | Office Equipment & Supplies
Minolta's DiALTA Color Series CF3102/2002 Service code 1220
Image control board not talking to a main control board, this mite take a while and mite quite costly if you can even fine the board if required to be replaced. First to reset open close front door, if the code comes back, you will have to begin by unplugging machine and removing each connector on each big printed circuit board check each connector on the boars for a bend pin the reseat each connector, next replace boards try site below, could try firm ware update via Konica Minolta Dealer ship they might have access to the secure server for firmware,
Used PCB Circuit Boards for Copiers PCB Assembly Circuit Board Repair
Oct 23, 2008 | Minolta Office Equipment & Supplies
MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Mar 07, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
673 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
