Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
I have a jenn-air electric wall oven model ww27110
The fan stopped working when i was using the self cleaning and now the fan does not work at all
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
here is a link to the diagram.
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
SOURCE: Selfcleaning Jenn-Air electric oven
door lock switch must activate for clean to work. door may not be shut completely.
Posted on Apr 10, 2008
SOURCE: Jenn-Air self cleaning wall ovens model W2451
We have a W245 self cleaning oven and the woven gasket is falling apart, can we purchase a new one to replace it?
Posted on May 08, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Aug 11, 2011 | Jenn-Air Ovens
Cannot get the oven cleaning feature to come on--fan only comes on.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Jenn-Air Electric Single Oven
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jan 16, 2008 | Jenn-Air JJW8527C Expressions Collection...
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
100 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
