Question about LG MU-60PZ95V 60 in. Plasma HDTV
Negative picture I have LG 60" plasma Monitor that picture looks like the negative of a photo. I can barely see the subjects and almost dark .I have sound and the picture geometry are fine.Any idea ? I have read something about replacing the Z board or the controller board but I am not sure if they are the problem I have AVMeter and oscelloscop and can use them if it required.Do not have the specific schematic but general with block diagram. thanks
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
  • 133 Answers
SOURCE: LG 42 plasma power problem
needs power supply Part number 6709900023A
it is a 171 dollar part, you should be able to order through LG,
Posted on Jan 10, 2009
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
  • 92 Answers
SOURCE: LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Posted on Sep 08, 2009
Heard a pop noise from LG 60PC1D tv, tv shut off and now the picture looks like a negative kind of...what is wrong?
Capacitor on the power supply popped and it is not allowing the proper voltage to be reached to the main board. This is messing up your picture. I would repair it before you create more damage from the blown capacitor on the power supply.
Please rate if this helped :)
Mar 08, 2011 | LG 60PC1D 60 in. Plasma Television
LG 60 in plasma turns off and back on randomly. Why is this and is it a bad thing?
I have a Lg 60 pg. It has sound but no picture what could be the possible cause?
Feb 21, 2010 | LG 60PG60 60 in. Plasma HDTV
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Picture went dark
This problem can be a bad YSUS or bad ZSUS and I recommend replacing both. The part #s are 6871QYH039B and 6871QZH044C. These parts can be found at Andrews or Vance Baldwin.
May 29, 2008 | LG 50PX1D 50 in. Plasma Television
Plasma tv
Hello
Check the contrast settings
If you are a Technician than just check the video supply from 150 to 200 volts at all three RGB Cathodes in most of cases there would be dry soldering in others it could be due to failure of supply resistance check base biasing voltages if u can provide more information then I could pin point the fault
Good Luck
Nov 16, 2007 | LG 42PC1DA 42 in. Plasma HDTV
LG MU-60PZ95V 60 in. Plasma HDTV Logo
81 people viewed this question
Computer Repairing
Computer Repairing
