Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Not staying cold or freezing
It it plugged in.
  • Anonymous Apr 30, 2009
    Fan motor runs, changed the relay kit on the compressor and it ran a few minutes and started to cool then it quit working again. Relay just clicks once in a while and compressor felt really hot. There are only two electrical parts that can be easily serviced, the relay and the fuse. 56.00 gamble for the fix and it didnt work. Looks like a new fridge is needed.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Can you hear if the compressor is running or not?
    Problem Solver:
  • 17 Answers
Unit has a leak and is low on refrigerant
Posted on Feb 10, 2009
I have a 2005 Malibu Maxx and my a.c. will not stay cold
If the A/C system is overfilled the evaporator will freeze and reduce the air able to go through it thus reducing cold air to the interior of the vehicle,so will not stay cold.
Also if the fan at the rad/condenser at the front of the vehicle does not work when the vehicle is stopped the A/C air will not stay cold.
May 08, 2017 | Cars & Trucks
Staying in hot water
With water rates on the rise, it is costly letting water run at a remote hot water faucet. It makes more sense than ever to insulate exposed hot water pipes in the basement with the foam insulation that's split lengthwise.
As an added benefit, freezing pipes can be avoided during power outages. The hot water pipes freeze sooner than the cold water ones because the freezing point of heated water is closer to 32*F than the freezing point of cold water. Cold water has a depressed freezing point due to dissolved minerals from municipal water treatments. Water that's been heated has fewer contaminants, hence less freezing point depression!
on Feb 28, 2010 | Washing Machines
Heater blows hot nnnnnnnthen cold ,,,,,,stays cold
To start, the first thing I would check is the fluid level in your cooling system. Do not remove the radiator cap if the engine is hot! The water will shoot out like a geyser and you could get burned or scalded by steaming hot water. Best to check it when the engine is cool.
If you need to add fluid it should minimally be a mixture of 50% water and 50% antifreeze. This way the fluid won't freeze in the winter or overheat in the summer.
Check the hose that runs from the radiator cap to the overflow container. Make sure it doesn't have any holes in it and it is not plugged up. Make sure the overflow tank has fluid in it to the level indicated on the tank.
These are basic, simple things to check. If these don't remedy the problem other possibilities are a bad thermostat, water pump, radiator cap, or a plugged heater core.
Feb 15, 2013 | Cars & Trucks
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Hotpoint hss25gp Not keeping cold or freezing
Check and clean the condenser coils where heat is transfered to the room air. If they are plugged with dust it will cause your problem. Check the back wall of the freezer for snow. If snow is on the back wall you have a defrost system problem.
Mar 09, 2008 | Hotpoint HSS25GFP Side by Side...
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
