Question about Eureka Boss Superbroom Bagless VacuumStick Vacuum
When using the hose attachment we are getting no suction
  • Ryan S
    Ryan S May 11, 2010
    Hi
    The Eureka Boss Superbroom bagless doesn't have a hose, perhaps its another model you are referring to here? Either way you need to return and put in the right model, name and model number.
  • 171 Answers
I would take a coin and drop it through the hose to make sure there is no blockage in the hose.also the machine must have the handle in the upright position for the airflow to be diverted from the power head to the hose.
Good luck and please give me a rating on your way out if you can remember.
Posted on Oct 12, 2010
  • 136 Answers
If everything is connected correctly, the hose is clogged
Posted on Aug 26, 2009
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
Why do I have no suction from our EP754C vacuum? Turns on but no suction?
Hi, please check the hose attachment you are using, sometimes tissue paper or fluff can cause the hose to block. You will have to remove any obstruction. Another test will be to check the area where the hose attaches to the vacuum, switch on without hose and use a piece of paper to see if there is suction in this area, if no suction then the problem could be that the inner filter housing the motor needs cleaning. Best of luck.
Jul 23, 2014 | Euro-Pro Shark EP754C Belt 2pk
BAD SUCTION WITH ATTACHMENTS
You may have a small leak in the hose somewhere, that may be getting bigger, thus losing more suction.
Jul 21, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Can't use hose attachments because no suction
chech the hose for a blockage this would cause the hose to compress as you describe
Jul 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
Eureka Boss Superbroom Bagless VacuumStick Vacuum Logo
52 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
