Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Engine it runs fine until i let off the clutch pedal
  • archtpf Feb 08, 2009
    thanks it is working fine now
    President:
  • 1,902 Answers
Check the ignition system. On the electrical start systems, there is located under the seat a relay. You can see inside that relay and you will be able to tell if it was popped or not. This switch will let the mower run until you try to move then it will stop the mower. Next would be to check the carb making sure you are not getting to much fuel and the adjustments are right
Posted on Feb 08, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 08, 2009
    Perfect glad to hear that, take care and have a great weekend or what is left of it anyways
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
My deere 133 runs until I let off the clutch it then shuts off
replace the saftey switch on the clutch pedal
Aug 06, 2012 | John Deere Garden
What could cause a clutch pedal in a 1996 honda accord to lost pressure
no fluid in the clutch reservoir due to a failed clutch slave cylinder
time to replace both the clutch slave and master cylinder
Dec 02, 2017 | 1996 Honda Accord
How to do a minor learning process to an actros
Minor:
press clutch pedal
press the N switch & keep pressed
switch on ignition you will hear sound or the N will display
release clutch the sound or the N
press clutch hear the sound
release clutch
end
Jun 30, 2010 | Mercedes-Benz Mercedes Bentz Actros Semi...
Clutch went to floor like nuthing was attached to it... runs fine just seems that the clutch pedal dont work or something it just floppy now...it happened when i was moving it in driveway was fine before...
There is a return spring that lifts the clutch pedal back to the original position. It seems that the clutch return spring has got disconnected. The pedal will do its job of disengaging the engine from the gear box, but will not offer any resistance to the foot and thus give an impression of doing nothing. So, that spring should be set right. For this the clutch housing will have to be opened and the spring reset.
Feb 10, 2010 | 1994 BMW 3 Series
Grinding when engaging into gear when warmed up.
ok every time you open the clutch resevoir you have to bleed the slave ..next hold down the clutch to the floor open the bleeder screw 10 mm bolt and then close it and pick the pedal up off the floor if your clutch is not right the pressure plate is failing most likely on mitstu stuff ...bleed first ..
May 08, 2009 | 1990 Eagle Talon
When i put into gear and press on the gas and the clutch out the engin revs but the car goes no where. I HAVE SIMMILAR PROBLEM. CLUTCH PEDAL IS VERY HARD ENGINE RUNNING, CAN SHIFT BETWEEN GEARS WITH...
WITH ENGINE ON & RUNNING and you are able to shift to any & or all Gears and with this theres,
No Clutch Engagement Upon Releasing Clutch
With Info Provided seems that you have 1 or all 3
of the Fallowing and they all Should be Replaced as A Set even if on lt 1 of them has Failed
  1. Clutch Pressure Plate has Failed
  2. Clutch Disc Is Worn Down
  3. Clutch Release Bearing Has Failed
All Require Removal Of Transmission this is the reasoning for Replacing all as SET with the Labor cost if your replace only 1 Item, and 3 Months later another of the 3 components Fail, you have the same Labor cost to PAY.
This Solution is Answering the SOLE Question ask, Barring No other Problems have or did Happen such as Noises Ran out Of Trans Lube. if it is the Clutch that has Failed and you are unable to Perform the Repair yyourself, DO SHOP AROUND get 5 or more Estimates as the Fee Will Vary Sometimes very wide gaps in fee's
and also Try and Purchase the Parts yourself Due to the Tremendous Markup of parts at Shops
I Hope I have Answered you Question to your satisfaction and if you have any more questions Feel free to Ask Me
Jan 13, 2009 | 1992 Toyota 4Runner
2002 Civic Dx Clutch?
i have just replaced an 03 civic ex clutch and transmission bearings due to a customer being too harsh on it. It sounds like its got a little life left in it if you are easy on it.
if there is adjustment in this model use the below walkthrough to adjust it.
adjust the clutch pedal,
1. if you look up on the top of the clutch pedal, the first thing you should see if a clutch pedal position switch, and right behind it there is a locknut, looens the locknut. once you loosen it, back off on the pedal position switch or adjusting bolt untill it no longer touches the clutch pedal.
2. now behind the clutch pedal, there is a pushrod. and on that pushrod, there is a locknut, loosen that locknut. Now turn the pushrod in or out to get the desired height and stroke at the clutch pedal.
The freeplay is the amount of push on the clutch pedal to where is starts to have resistance from the top. I have usually been told it should be set at 1 1/2-2 inches of freeplay.
Once you set it, tighten the locknut on the pushrod. With the clutch pedal released, turn in the clutch pedal position switch untill it contacts the clutch pedal. then turn it an additional 3/4 to 1 turn. And tighten the locknut.
Now on top of the clutch pedal switch, there is a clutch interlock switch. Loosen the locknut on that switch. then press the clutch pedal to the floor.
release the clutch pedal 15-20 mm (0.59-0.79 in) from the fully pressed position, and hold it there. adjust the position of the clutch interlock switch so the engine will start with the clutch pedal in this position. then tighten the locknut on that switch.
Hope this helps
Nov 28, 2008 | 2002 Honda Civic
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
71 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
