I just purchased and installed the DIR-655. The direct connection links are up, running and working well. The issue we're having is with two different laptops that are 'b/g' wireless capable. We will see the router from time to time and sometimes are able to connect, however the link will not stay up nor are we able to see the router continuously. It does not matter how far or close we are from the router. I have tried secure and unsecure modes and have upgraded to the latest version of the firmware (1.07 Dec 08). Is this a HW defect or is there something else going on????
Thanks
Any one with a mac ... MAKE SURE "Enable Auto Channel Scan :
" is OFF.
CHANGE the name of the WIFI Network.
SET the Channel to CH11 [Others interfere with phone signals]
SET Security to WPA, TKIP Cypher, 3600. Then enter your password [min 8 all lowercase chrs] Change it when you are working.
Save and unplug the router and you will be fine.
I have DIR-655 myself and my Firmware version is 1.21 which is the latest. So 1.07 cannot be latest
Sorry, it seems that you have posted clarification about 1.21 at the same time I posted my clarification. This signal drop is not normal. If you purchased at a store where you can easily return or exchange, I'd do it. Otherwise, call D-LINK techsupport.
By the way, does the router have enough air flow from the top holes? Is it very hot to the touch? It might be just overheating... Just a thought
Sorry - wrong version posted for firmware...it is 1.21, 2008/10/09
Here are some entries from the logging....wireless keeps going p and down....
[INFO]
Sun Feb 08 15:34:46 2009
Log viewed by IP address 192.168.0.103
[INFO]
Sun Feb 08 15:34:40 2009
Above message repeated 2 times
[INFO]
Sun Feb 08 15:34:34 2009
Wireless link is down
[INFO]
Wireless restart
[INFO]
Disconnect all stations
[INFO]
All Wireless shut down
[INFO]
Sun Feb 08 15:34:32 2009
Wireless restart
[INFO]
Sun Feb 08 15:34:29 2009
Above message repeated 1 times
[INFO]
Sun Feb 08 15:34:27 2009
Wireless link is up
[INFO]
Sun Feb 08 15:34:18 2009
[INFO]
Sun Feb 08 15:34:05 2009
[INFO]
Wireless restart
[INFO]
[INFO]
[INFO]
Sun Feb 08 15:34:04 2009
[INFO]
Sun Feb 08 15:34:02 2009
Wireless restart
[INFO]
Sun Feb 08 15:34:00 2009
Wireless link is up
[INFO]
Sun Feb 08 15:33:37 2009
[INFO]
Wireless restart
[INFO]
[INFO]
[INFO]
Sun Feb 08 15:33:35 2009
Wireless restart
[INFO]
Sun Feb 08 15:33:33 2009
Wireless link is up
[INFO]
Sun Feb 08 15:33:32 2009
[INFO]
Sun Feb 08 15:33:10 2009
[INFO]
Wireless restart
[INFO]
[INFO]
thanks - but if you notice my correction I indicate 1.21 is the version I'm using.
I've returned the item....
Same here.. I've had the same problems with hardware rev. A2 and A3
DIR-655 hardware A3 firmware 1.21,
Wireless with WPA2-PSK/AES in g/n mode,
Wireless client connection keeps dropping and reconnecting,
DIR-655 logs "Wireless restart" coinciding with client drop,
No other interesting log entries or wired interruptions during these events,
Wireless survey shows no other nearby AP's on neighboring channels.
Same here.. I've had this with rev A1, A2 and A3.
I get the same problem with the wireless connecton dropping. The reciever is about 18 feet away with two interior walls between it and the DIR-655. Signal strength at the reciever is 100%. Walls are perpendicular to the two devices so the signal should be good.
From broadbandreports forum:
Please try following the guidelines below :
a. Ensure that the antenna of the router/access
point is positioned for best reception. You would
need to determine the best orientation for the
antenna in an ad-hoc manner by trying out the
different possibilities yourself. Take care to keep
the product away (at least 3-6 feet) from
electrical devices that generate RF noise, like
microwaves, Monitors, electric motors, UPS units, etc.
If you are using 2.4GHz cordless phones or X-10
(wireless products such as ceiling fans, lights,
and home security systems), your wireless
connection will degrade dramatically or drop completely.
Anything using the 2.4Ghz frequency will
interfere with your wireless network,
b. Try changing the WIRELESS CHANNEL of operation
on the router/access point. Experiment with
different channels till you find one which presents
you with minimal interference,
Please refer the link given below to change the
channel on the router:
»www.support.dlink.com/faq/view.a···=channel
c. Set the PREAMBLE to SHORT on both the card as
well as on the wireless router (under ADVANCED >
PERFORMANCE for the router),
preamble to short on the router:
»www.support.dlink.com/faq/view.a···preamble
d. Try locking up (lowering) the speed on the
wireless router and on the wireless card as well.
Try different speeds till you get one that gives
you reasonably good speed as well as a consistently
good connection,
e. Finally, move the router closer. Try getting
the router and the wireless PC into direct
line-of-sight though you might have physical obstacles
in between,
In case you are using WEP, DISABLE the same if it
is not absolutely necessary, because WEP as such
involves a lot of added overhead.
These should bring about considerable improvement
in the quality of your wireless link.
I did as they suggested. And it's working now. I'm glad I don't have to but a new router.
