Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven runs but does not heat.
It's a Model JEM25 GY/Wy counter top unit. When I unplug it and then plug it back in, it resets and works for a while and then quits heating again. So far I have been able to reset it 3 times.
Dan
    Problem Solver:
  • 17 Answers
MOST PROBARLY YOU NEED THE DOOR SWITCHES
Posted on Feb 08, 2009
Reset button
Unplug,then plug back in,wait 10 minutes,or try another outlet,circuit breaker could of turned off at control panel in house,reset it.
Mar 04, 2017 | Microwave Ovens
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
The microwave turns on but does not heat food. i reset the microwave by unplugging it for 2 minutes. once plugged back in, i reset the clock. i made sure the unit was not in demo mode. it still does not...
A part called the magnetron tube supplies the microwaves which heat your food. It's possible the tube has gone bad. It's also possible that other problems are keeping the proper power from being applied to let the tube work.
Microwave ovens use hazardous voltages WHICH CAN KILL YOU, so troubleshooting is best left to professionals with the tools and experience to work on them safely. If this is a basic counter-top oven, it may be more economical just to replace it. Otherwise let a qualified technician determine what has gone wrong and give an estimate to repair.
Sep 02, 2011 | Microwave Ovens
Microwave KOT151S under counter model quit working right after installation. Power from house is funtioning, but the only thing working on microwave is the interior light. Is there a built-in fuse within...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If some keys are still unresponsive, your membrane keypad has failed.
This can be due exposure to excessive heat, moisture or condensation, such as
due to storage in an unheated building.
It's usually economical to order a whole new controller here.
Let us know if we can help you further.
Aug 21, 2010 | Kenmore 80412 Microwave Oven
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
It looks and sounds like it is working, but there is no heat.
You will need to replace the Magnetron. this will restore the heating action in this unit.
May 27, 2009 | GE JEM25 Microwave Oven
Microwave making a different sound and not heating as well
there migth be a problem with the exhaust fan inside the oven.the motor shafting and bushing might need some oiling.try it ,the motor is easy to acces.be sure it is unpluged.because you are wogking cklose to the high voltage
Dec 20, 2007 | GE JEM25 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
73 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
