Question about Sony KP-46WT510 46" Rear Projection HDTV
Double Image Red and Green
The TV turns on with volumn. The screen shows double images separated by about 3 inches. The top image is closed to normal but it accented in the color green. If therer is writing associated with this image it is mainly green in color. The second image which appears just below the first is the same image only it is mainly red in color. The writing for the second image appears proportionally below the first line of text but is red in color. When the "menu" button is chosen there are two lines for each selection again in green and red.
  • Anonymous Mar 25, 2009
    I have the same problem except my images are side by side about 3 inches apart. It was ok when I turned the tv on and then suddenly the picture changed. I have a Hitachi big screen tv about 8 years old.
  • Sony Master
  • 3,459 Answers
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common prDouble Image Red and Green - 2c07611.png/>
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 10, 2009
  • 10,594 Answers
It is failure of Convergence Out ICs in your TV and needs to be replaced either ICs or Convergence Board.
Let me know exact model number of your Sony TV to provide you more info.
Posted on Feb 08, 2009
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Red and Green have separated in double image and there is a dip at the top. Please Help.
You have a defective CONVERGENCE IC. Most TV use 2 identical STK IC & both has to be replaced at the same time. If you are not a technician I don't recommend doing it yourself. There is a lot of desoldering to remove the chips with 16 or more pins- and soldering the new ones.
Good luck! Astrotech
May 28, 2009 | Hitachi 51GWX20B 51" Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
61 Hitachi Ultra Vision has double image
Replace both of your STKs big black ics If they are STK392-110s upgrade to 180s better ics Electronix has them call 1-800-223-3205
Dec 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
580 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
