Question about Proview PS 909 (White) 19 in.CRT Conventional Monitor
LG Monitor will go black, other programs still run fine
Monitor will go black out of the blue. Other programs that I'm running at the same time still work (like ventrillo). I turn off the computer. Turn it back on it's fine again until it decides to just randomly turn off again. If I turn the monitor off during one of these black episodes and turn it back on. It blinks LG and then will not turn off all the way. Is it my monitor or my computer overheating?
SOURCE: Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Posted on Jul 24, 2007
SOURCE: proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Posted on Dec 11, 2007
computafixa
  • 317 Answers
SOURCE: Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Posted on Feb 21, 2008
sparkyuiop
  • 91 Answers
SOURCE: 1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Posted on Oct 20, 2008
Fix-4U
  • 293 Answers
SOURCE: Monitor takes a long time to come on.
Hi..there,
Well, it's not your monitor. It's seems your PC had lots of garbages or spywares. Need to cleaned out all the junks in your C: Drive...Right click on your C: Drive and click on properties and click on Disk Cleanup after that check all the boxes on right handside. Then click OK and Yes. That should clean up all the junks in C: Drive. Cleanup all the junks every Weekend. Then run a virus scanned for virus and spywares...and set to scanned very night...
Posted on Nov 21, 2008
Acer aspire x3390
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 26, 2012 | Acer Computers & Internet
WHEN PUTTING IN GAME IT RUNS IN BACKGROUND, BUT BLACK SCREEN WITH BLUE BOX SAYING ANALOG OUT OF RANGE WITH NUMBERS
hi
press F7 to bypass that error and if did not work use another monitor to adjust the setting resolution of your pc into 800x600 and plug again the flatron monitor.
just leave a comments and i will assist you
thank you
Mar 14, 2011 | LG 22" FLATRON LCD Monitor
Dell laptop monitor will not boot sometimes stays black. . .runs in safe sometimes also will lock up in programs...very quick blue screen upon boot sometimes as well can't tell what it is doing.
The issue is not with your monitor. Its with your computer's operating system, it may be corrupted and needs to be reinstalled. Getting on safe mode all the time is also a sign that your hard drive is about to fail, I suggest that you back up all your data now...
Jun 13, 2010 | Computers & Internet
I have my LG LCD flat screen TV, accidentally i bottle of Soda burst on the screen, i wipe it a dried it using a dry cloth, the next morning i have this black spots on my screen, please help
If you are sure its not a stain. then its a dead pixel on your monitor.. sooner or later it will spread out. To be sure if its a dead pixel, run your monitor in different colors, black screen, green, red and blue.. If the spots stays then its dead pixel.. You will be replacing the lcd when time comes that it spreads out.
May 18, 2010 | Televison & Video
Major Display Problems
your card is defect, just replace and ok
Feb 12, 2010 | LG Studioworks 900B 19" CRT Monitor
The monitor turns black immediately after power cycle
i think it can be the capacitor problem, open monitor an look for swollen capacitors. if you will find them swollen or mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:IT;} @page Section1 {size:8.5in 11.0in; margin:56.7pt 42.5pt 56.7pt 85.05pt; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loosing the electrolyte, signs of burn, change them
Apr 12, 2009 | LG 22" FLATRON LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Lg w2242t lcd screen is one week old and goes black occasionally when zooming or changing windows, it plays video perfectly, running dvi connection and latest lg driver, rolled back driver to windows plug...
According to your manual, the recommended resolution for this monitor is 1680 x 1050 @ 60 hz. Is this the display setting you are using? Manual is at http://www.lge.com/products/mobile/cdma_manulist_gcsc.jsp.
You should be able to use the driver supplied by the manufacturer, and it should not cause problems! If you are in the U.S., support contact info is at http://www.lge.com/support/gcscWrite.jsp, and includes phone number. Given that this monitor is new, I would suggest telephoning LG for support, and if it is not resolved sufficiently, returning the monitor. This monitor should run perfectly with the supplied driver, and if not, there is a hardware malfunction or conflict. LG should be able to tell you definitively if there is a way to solve the problem, and if not, suggest that you return and replace it.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jun 02, 2008 | Computers & Internet
Monitor goes black with a white horizontal line across the middle of the screen
Check to see that the monitor cable is correctly installed. Also, make sure you have the most up-to-date drivers installed for your graphics adaptor card(both ATI and Nvidia carry catch-all driver programs to keep you up to date.) Tighten the cable screws of course, to make sure the monitor cable isnt just wiggling in its seating.
Jun 05, 2007 | LG Studioworks 900B 19" CRT Monitor
Proview PS 909 (White) 19 in.CRT Conventional Monitor Logo
57 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
