Question about Harvard Xh 7000 Hockey Table
Scratches / cuts in play surface
I have a used table that has been used as a cutting surface.
4 or 5 cuts on the surface of the table deep enough to feel and the
puck "clicks" as it travels across. I have though of gently sanding and
then rebuffing to remove.
Any suggestions?
    President:
  • 2,976 Answers
The scrathes can be made flush with the surface by laying a flat file on the surface and rubbing them down. A coat of car wax will bring back the surface.
Posted on Feb 13, 2009
  • 51 Answers
Ok this Is A Very Very Easy Fix all you need is either carpenter putty or mighty putty and you fill the cracks and sand it down. therefore creating a smooth surface and if you want put gloss to make it slick.
Posted on Feb 11, 2009
Can you freeze raw potatoes and how do you do this?
i assume you want to pre-prepare chips for big family gathering? or for any period of time.
you need good freezing unit
potatoes
chips cutter
knife
3ltr (1 gallon) water with bit of salt and bit of vinegar in it
5kg (11lb) potatoes
table spoon
method:
water solution: to 3ltr (1 gallon) of water add and solve about 6 table spoon of salt and about same amount (6 table spoons) of vinegar (this solution will prevent blackening of the potato cuts), i am adding as well about 3 spoon of sugar to the solution, it allow liquid to cling better to the surface of potatoes, water should be cold, even few ice cubes in it will help
1. wash well your potatoes from debris, sand and whatever junk, remove unsightly, damaged or rotting bits from the potatoes
2. if you have chip machine or slicer - use it! chips should be not thicker than 12mm (1/2"), try not make them thinner than 3mm (1/8"), i do not bother with skinning them, but you may if you have masochistic tendencies. you can do that with knife as well, but will take longer. chips can be cut as straws, plates, sticks. waffle or whatever pattern you have in mind
3. chopped chips drop into the water solution and frequently stir as to allow all surfaces to be covered and prevent browning/blackening of the surfaces (this is oxidation of the surface, it is not poisonous but looks ugly)
4. after all potatoes were used, strain them from water, shake excess water and spread single layer on greaseproof (baking) paper or any other non-stick surface
5. your produce now need to be transferred to the deep freezer and frozen, minimum temperature should be -18c (0f), preffered will be -32c (-25f), if you are living in climate where these temperatures are outside, just put them outside...
6. after deep frozen (about 6h to 12h) divide them and pack them in sealed bags, in suitable portions
that way prepared chips can be stored for months, and if at lower temperature, even for years.
to fry:
have suitable fat at temperature of about 185c (365f), or whatever settings on your fryer is, you do not need defrost them, just directly from the fridge to the fryer, from the moment when they float, about 2min or until golden brown
enjoy!
if you like the recipy - why not vote for it?
Jan 01, 2015 | Microwave Ovens
I have Model RF1101 Router mounted in a router table and I'm trying to cut a dovetail groove in a workpiece. I first use a straight bit with 2 flutes to hog out a 1/4" deep groove. For some reason...
I've had this problem with off shore bits, where the machineing on the shaft is slightly under spec. The bit wobbles out of the chuck because it can't be tightened enough. Try a different bit.
Feb 02, 2011 | Saws
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
How do i restore the surface of my outdoor ping pong table
Use painters tape to cover the white lines of your table tennis table.
Use sandpaper (150grit) to smooth the surface. This will level any bumps or scratches. Fill deep cracks with wood filler, let it dry and sand the table again.
Make sure that the table is clean before you begin the painting procedure.
Use chalkboard spray paint about 8 inches away from the table and spray each side. Allow 8 hours for the paint to dry then repeat with another coat. Next day, repeat the process so you have 3 layers of paint. Chalkboard spray paint helps the ball bounce to the correct height and speed.
Remove the painters tape after the last coat and allow the table to dry for at least 24 hours.
Hope this helps, vote me if so :)
Jun 30, 2010 | Kettler Stockholm Outdoor Table Tennis...
Right side of screen scratched how can I fix it
If the screen does not have deep scratches, then you can polish the scratches out using a car polish cutting compound.
Mar 05, 2010 | LG Xenon GR500 Cell Phone
I have scratches what should i do?
If the scratches on the display are not too deep, you maybe able to polish them out using a car polish cutting compound.
Feb 11, 2010 | Samsung Behold Cell Phone
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Cutting chamfer on oak wood
One way to do it is to use a table saw, with the blade cranked over at an angle, feeding the piece through upright, with the flat against the fence instead of down against the table surface. You can make a very shallow angled cut in this way, and it's accuracy is improved through the use of fingerboards to hold the work against the fence.
If you have a router table with a fence on it, you can set up a panel raising bit and do a fairly shallow cut on the edge of your threshold, but probably not as deep (from the edge) as on a table saw. (Probably only about 1 1/2" vs up to 3").
The most laborious method, but fairly simple, is to make some kind of sled-like jig for the router that will span the width x2 of your board, then mount the board on a large flat surface at the desired angle, and use a flat bottomed bit to essentially plane the board by hand, sliding the router back and forth from end to end, moving it over to make the next pass, and so forth. Slow & dusty, but effective nevertheless.
Here's a link I found with pictures of something like what I was thinking of. Router planing jig
Whichever method you choose, expect to have to dress the cuts with a belt sander to smooth out the machine marks.
If what you're after is a simple 45 degree chamfer, just buy a chamfer bit with a bearing, and if you wish to take more cut than the thickness of your workpiece allows, screw another board flush to the edge underneath to guide the bearing against while you make your cut.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 05, 2009 | Tools & Hardware - Others
Adjusting the outfeed table on the Delta Model: JT-160
Sometimes you just have to shim them. If you've worked the gibs and can't get any more adjustment out of them, you might try buying some thin brass or copper metal stock (you can get it in rolls at Hobby Lobby) and use it as a shim to hold the table in the appropriate position.
It sounds crude, but that was the only way I managed to get my industrial 6" powermatic to true up.
Also bring the infeed table up to zero, aligned exactly with the outfeed table and check with a known true straightedge. This will help you to keep a clear idea in mind of which direction to move things when you're making adjustments.
If you can get the edges and diagonals straight, you're well on your way to straight cuts.
Make sure beforehand that the surface you're fixing to is flat and you're not clamping the machine down in a way that's torqueing the base.
Castings just aren't rested long enough these days before the surfaces are ground, and things twist a bit sometimes. You may be working with a surface not flat, and unable to get it perfect.
Good luck. I hope that helps a little.
You may need to use an auxiliary roller stand to support the outfeed of long boards to keep the weight from causing a droop that lifts the tail off the tables and prevents a straight cut.
Mar 12, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Harvard Xh 7000 Hockey Table Logo
475 people viewed this question
Top Harvard Toys Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Harvard Toy Expert? Answer questions, earn points and help others
