Question about Toshiba 36A40 36" TV
Picture clear, then "grainy" can hit TV and will clear up
Just started doing this; is this something that can be repaired or is it time for a new TV? Picture will be clear, then change to a "grainy" picture--but we can hit the side or top of the tv and it will go back to clear--sometimes for 5-6 hours, sometimes less.
  • 55 Answers
Sounds like a cold solder joint in the tuner circuitry. Unless you can do it yourself it's probably not going to be worth the repair bill.
Posted on Mar 09, 2009
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Tv repair for vior 42 inch something wrong w the screen the and not clear but the voice and rest is working picture very grainy poor focus
a dull picture is usualy caused by the z-sustain board but i have known the y-sustain give the same symptom sorry cant be any more help these boards can run quite expensive try getting used ones from ebay i would go for the z-sus first
Oct 25, 2011 | Toymax Viore 42 in. Plasma TV
Grainy bdmv platyback
You have a couple of options.
1. Turn down the sharpness on your TV. Too much is overkill, anyway.
2. Whilst watching any movie, hit the triangle button for the movie settings & options. Turn up the noise reduction to +3, also the "mosquito" noise to +3.
These should give you a less grainy picture. Enjoy!
May 29, 2009 | Sony Playstation 3 (PS3) Console
Grainy Sky+ Tv picture
Can't say it's a fix but when you press the tv button to make the picture better, cover the end of the remote and press sky so the tv and box don't pick it up.
It's more of a work around than a fix!
Mar 30, 2009 | Panasonic TH-42PHD8UK 42 in. Plasma...
Picture goes out of focus
This is a classic example of a bad connection that sufficiently changes a circuit characteristic to cause a problem. If you can solder, you can fix this yourself. Look for any connections on the board that appear grainy or have rings and resolder them. That should resolve the problem. Note: there are potentially dangerous high voltages present inside the set even when unplugged. So be careful.
Dan
Feb 25, 2009 | Sony Televison & Video
Not able to select HD on my Wii setup screen
Well see if it happens again, it may have been a one time thing. but try reconnecting the AV cables to the tv or change the picture settings on the wii setup options.
But this is important, is the picture grainy, or is there vertical black lines? if its black lines, i have the same problem and the only way to fix it is to send it to nintendo and theyll give u a new console. its due to overheating and the graphics card gets fried
Sep 02, 2008 | Nintendo Wii Console
Samsung LE37R8 LCD TV
I need a bit more detail on the word "GRAINY". At the outset, your description indicates a poor signal source, but then the word grainy leaves the door too wide open. Clarify please.
Bri
Jun 08, 2008 | Televison & Video
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Picture in picture / or picture problems
First thing you should try is unplug the set for several hours. If you have the same problem, then you are going to have a system control issue and or a standby power supply issue. These problem, unless you know how these circuits work in a TV set, will need to be looked at by a trained tech. Good Luck
Aug 13, 2007 | Sony KV-35V75 35" TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Toshiba 36A40 36" TV Logo
153 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
