Question about Dymo LabelWriter 400 Turbo Thermal Printer
How tp print an all black label
I need to print a label to cover another label, anyone know how I can do that, when I just type loads of text it just goes smaller, I need to completely fill the label.
Thanks
  • applianceuni Feb 08, 2009
    that may affect the adhesive I fear :)
    Genius:
  • 2,120 Answers
Put one in a 170 degrees oven.
Posted on Feb 08, 2009
I want to print a label onto a DVD I am burning using my HP6180 All-in-one printer. Does anyone know how i can do it?
Your printer is not printing straight to a DVD, so you will have to buy self adhesive labels, print on them and then stick the label on the disc. Now, it all depends on what software you have available. Your might have software included with the Photosmart printer for CD/DVD label printing, check your installer CD that came with the printer. If you don't, and use Nero for burning DVDs, you may notice it has a label printing software that comes with it. You will need this type of software in order to print a label. If you don't have Nero, or any other label printing software you can try using some of the free ones that are out there, like Disketch 2.11. There's also a lot of free to try label printing software, like Acoustica CD DVD Label Maker which you can use for 15 days for free. If you have Photoshop and you're good using it, then this is another option to consider (you can download templates online).
Using a label printing software is pretty easy, most of them will have templates that you can open and just edit, or you can start with a blank design and add text and pictures to it. When you are finnished put the special label paper in the printer and click print. If you have special DVD labels make sure you specify that in the printing preferences before you print.
Dec 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Jul 14, 2008 | Printronix T5000r Label Printer
Canon PIXMAiP4500 printer
Select the print dvd/cd cover application, when it opens it shows the outline of the label
Select 'text' and type your text, then adapt it by font, style, size and positioning.
Can preview on the label and drag it around like a text box in MS Word
For images, select 'insert' from the menu on the screen, browse to your phots and select one, then accept it and preview/resize on the label shown on the screen
Then select 'print'
Get your cd hol;der ready, open the front of the printer, then open the flap with 'Canon' on it
Wait foir screen prompt to insert the holder, with the cd upwards facing and at the end nearest the printer
When prompted, insert it so the 'arrows' on the left and right are flush with the front edge of the flap you just folded down
Jun 01, 2008 | Canon iP4500 Photo Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
50 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
