Question about RCA L42WD250 42 in. LCD HDTV
RCA L42WD250 42 in. will not turn on
After having the set for six months I moved it to another location. I went to plug it back in and the front light is green. When I hit the power button on top the screen flashes once and nothing happens. The flashing light is now red. I have no controls or buttons. I can't find my service book that I got with the LCD to find problems. RCA help is worthless. Any idea what is going on? or where to go for help.
    President:
  • 1,077 Answers
Try unplugging it for 30 mins. If it still has the problem, it may have when into protection mode.
When this happens, a part in the TV when bad. The protection mode keeps the TV from staying on to prevent further damage.
At this point, I would use the warranty on the TV. Being that it's only 6 months old.
Posted on Feb 09, 2009
52" RCA Scenum froze and would not turn off. I unplugged it and then plugged it back in. All the lights are on in the front of the tv but it will not turn on.
The small signal board is the most likliest cause of that issue which is a very famous symptom for the ITC222 and ITC222A chassis RCA models. You can usually get the small signal board from www.tvrepairworld.com several versions were used so they can assist with identifying which version ssb your model requires.
Apr 03, 2013 | RCA D52W19 52" Rear Projection Television
We have a 2004 RCA hdtv model #D52W20 - we were using it and gave it to our kids - unplugged it and then it set for almost 8 months. when it was plugged in the green light on the front came on for...
thats almost always caused by the CP150, CP120 and CP114 capacitors failing on the deflection board. You can get the RCA repair kit called the CP150, CP120 and CP114 repair kit from www.tvrpairworld.com which has the capacitors and the CD with repair instructions.
Oct 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have a Westinghouse flatscreen, three years old that has been acting oddly for more than six months. First the picture would roll through the channels for no reason and stop at any channel and be good...
think that their might be a loosed connection. Try to remove the back cover of your tv but be sure to unplug it, remember the location of each screw. then you will see a connectors try to press or unplug then plug it, be sure to return the connectors in their respective slots. then try look the pcb board the solder side try to observe if their is a weak solder, then if see something try to resolder it but be sure not to connect the separated pins to avoid short circuit to the unit.
Jul 02, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
The lamp has just been replaced and now the tv will only stay on for 30 minutes and then turn itself off. The lamp indicator light is red. We can turn the tv back on and the light goes off. Six months ago...
Did you press the System Reset button with a ball point pin on the front of the set? You might have a ballast going bad if it has never been replaced. But first, the reset button then you may have a thermal switch which is located just above the lamp housing. I test the thermal switches by unhooking (while set is unplugged) one of the wires and then putting an alligator clip jumper between the two wires to see if it last longer than the 30 minutes you mentioned. Lastly, there must not be any dust in and around the fan which can cause overheating. Sounds like you have an overheating problem initially. The thermal switch cuts the set off if there is overheating. And also if the switch is faulty it will cut off the set. Also look in the menu for a temperature setting if this model has a setting such as this.
May 24, 2011 | Mitsubishi WD73727 73" HDTV
Why does my "check engine" light keep coming on?
Scan it for codes. Forget six months ago and the gas cap. You have new issues to work on.
Mar 10, 2010 | 2002 Dodge Caravan
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
All lights flashing
Try opening the font cover, press the GO button six times and then close the front cover.
Aug 09, 2008 | Brother HL 5250DN Laser Printer
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
I've lost power, how do I reset the time?
Move slide switch on back left to "clock" position (all the way right) and then use "up" and "down" buttons to set time. Then slide back to "lock" position.
The controls for day light saving (or not) is located on back extreme left (i.e.. turn the unit around and look on RHS).
Dec 05, 2007 | RCA RP5420 Clock Radio
RCA L42WD250 42 in. LCD HDTV Logo
372 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
