Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Chamberlain Garage Door Opener will not close door
I have a Chamberlain 1/2 HP Garage Door Opener and when I push the button on the remote or wall it just starts clicking and won't close. This problem has gotten worse and when it first started the door would go almost all the way down and then come back up. It seemed to always open ok too.
I have tried adjusting the "Close Force" button and the sensors seem to be aligned correctly. I have also greased up the rollers.
Anybody have any idea what could be wrong here? Thanks to all who reply......
  • 1 more comment
  • hgilgen Feb 09, 2009
    Thank you for the reply. I believe both of the sensors are working properly. One has a green light on it and the other an amber light. I was messing around with it again yesterday and when I disengage from the door it will sometimes go all the way through the motion without stopping, but sometimes not.
  • hgilgen Feb 12, 2009
    I think I may have this fixed now. I messed around with the eyes for about 30 minutes and think I may have finally gotten them lined up right. I don't know how they got so out of whack?!? I had to slightly bend the bracket back and then the green light got really solid. I didn't think it had to be that solid. Before the little green light was flickering a bit.
    Thanks a lot for your responses guys. You may have saved me a few hundred bucks!!! I was ready to buy a new opener this weekend.
  • bdevolder Feb 18, 2009
    The sensors are lined up (both solid LED's). The orange LED on the back of the machine flashes 4 times when I try to close the door. A previous post set to check the manual, but we just bought this house without the manual for this (the machine looks very new).
    Hope somebody can help.
  • 30 Answers
It is most likly your sensors You should not have to mess with your force settings but I can help you with your sensors assume you have checked to make sure there both looking at each other. First close the door so you can see them better. Tap each one of the sensors to see if any of the lights are flickering. if your then you need to tight them up and try again. Also when its dusk or night close your garage door and look at the lights see if one of the tracks is shaking sensor. If not check the wires make sure there is not staple or cuts in them. Then last thing you can check see if your door is hitting the back of the sensor mount it does happen. Also remove and ropes or handles you have fromt eh buttom of the door. That should take care of the problem. Make another post if your still having problems
Posted on Feb 10, 2009
  • 118 Answers
The problem is with the safety eyes. Make sure that both eyes are lit. If not, align them making sure that they are pointing directly at each other. Also, if you adjusted the force setting make sure that it is not turned up past 5 or it can be dangerous.
Posted on Feb 09, 2009
  • Vince Heuser Feb 09, 2009
    The next thing to try is take off the cover and see if the gear is stripped. If it is the bottom will be full of white shavings
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 139.53879 remote won't learn the code of my 1/2 HP craftsman receiver type 132C2105-3B. I followed the directions to push the transmitter button and hold the receiver button down until the...
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening/closing problem
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
872 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
