Question about Intel Motherboard
Grphic problem with lcd
The board can not supply resolution for 19" wide lcd screen the required resolution is 1440 x 900
  • 70 Answers
Without the specific model of your motherboard, I can't say for certain, but I would guess that the onboard video does not support that resolution.
If that's true, then your best option would be to purchase and install (or have installed by someone) a new video card. Most new video cards can support higher resolutions.
Posted on Feb 08, 2009
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
I have SAMSUNG LCD 943 MWX monitor which is 19"
This is not a monitor problem.This is a mother board problem, some mother boards are supporting this resolution.For this problem,you have to replace the mother board or put the graphics card on the same mother board.your problem will solve.
Feb 18, 2011 | Samsung 943NW Monitor
Does the PL926wbi have a webcam built into it
No, Proview PL926wbi does not have a webcam integrated.
Product Attributes dot2.gifDisplay Technology: LCD dot2.gifHorizontal Viewing Angle: 150 dot2.gifMonitor Screen Size (inches): 19 dot2.gifMonitor Screen Size Range: 17" - 19" dot2.gifPixel Pitch: 0.285 dot2.gifProduct Model: PL926WBI dot2.gifResolution: 1440 x 900 Maximum Resolution dot2.gifResolution Width: 1440 dot2.gifVertical Viewing Angle: 130
Thank you and please rate.
Jan 13, 2011 | Computers & Internet
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
I have changed to an Acer 19in wide screen monitor, my photo albums appear as wide screen pics
You need to set the PC video resolution to 1440 x900 @60Hz which is the native resolution of this monitor.
Mar 17, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Aspect ratio
increase the resolution to the maximum then check
Apr 17, 2008 | ASUS LCD Monitor
View sonic va1930wm 19' wide screen
hi there, first boot go to safe mode and choose the lowest resolution, restarting the unit and you can adjust the resolution to the high stage one by one. ty
Jan 09, 2008 | Gateway FPD2275W LCD Monitor
1440x900 resolution required
check and make sure that you are using the Intel drivers and not the default windows xp drivers. The default drivers are very limited and only offer a few different resolutions to choose from.
Nov 20, 2007 | Intel D845GVSR Motherboard
Images on monitor are enlongated
Is the resolution set to the monitor's native resolution? Your video card must support the monitor's true resolution, this is particularly important with wide-screen LCD monitors.
Nov 20, 2007 | Hyundai L91A 19" LCD Monitor
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
